manual glow plugs
Old Oct 21, 2009 | 03:47 PM
xjvince's Avatar
xjvince
manual glow plugs
I would like to use a push button for my glow plugs. I know some of you guys are familiar with this. are some ways better than others? will it work only with key "on" ? any pics and advise would be appreciated.
Old Oct 21, 2009 | 08:37 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
a search will yield a lot of info for doing this.but most seem to agree,when possible,fix the problem(s) causing hard starts to original.just fyi.
Old Oct 21, 2009 | 11:22 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The 94 has power supplied to the relay trigger coil by the ignition switch.
So the easiest way does require the key be on to use them, and provides a bit of safety that the glow plugs can not be activated when the key is off.
Remove the white wire, attach a wire to that terminal and run it in the cab to a momentary switch.
Attach another wire to the momentary switch and run it to a good electrical ground.
Done with the install.
Turn the key on, press momentary switch for 10 seconds, start the engine.
What problem are you having with the controller?
If the glow time for the first start of th eday is less than 10 seconds, you probably have burnt out glow plugs.
Manual control will not fix that.
Keeping the plugs on longer will burn out the remaining plugs that are working now.
Check the glow plugs with a multimeter, .5 to 1 ohm resistance on each plug, check them seperately.
Replace any that are outside that range with Motorcraft/Beru ZD 9 glow plugs.
Old Oct 22, 2009 | 03:01 AM
xjvince's Avatar
xjvince
my truck is only operating on 7 gp's. it has a tip broke and stuck in one hole. its been this way since I've owned it. 2.5 yrs, 20k mi. I discovered this shortly after my purchase. the previous owner had cut off the end of a old plug and screwed it in over the broken tip as a cap and didn't hook the connector back up. I put in 7 new motorcraft plugs. the truck starts OK but is fussy when its freezing out. right now the glow time is maybe 5 seconds at best. I thought maybe a manual button would help warm them up a bit more. I'm going elk hunting in a couple weeks and its gunna be COLD!
so basically my switch provides a ground for the terminal the white wire was hooked to? do I just tape up the end of the white wire and let it be?
Old Oct 22, 2009 | 06:44 AM
LCAM-01XA's Avatar
LCAM-01XA
Don't even need to tape it off, it only sees power from the relay - if it's off the relay it won't see any current through it. Personally I'd just slide a piece of heat shrink over the ring-terminal, then tuck the wire away from the relay, maybe ziptie it to some other wires?
Old Oct 22, 2009 | 09:11 PM
Dave Sponaugle
The white wire normally has no current on it.
When the glow plugs are to come on, it goes to ground through the controller.
About the only way it would cause a problem is if it came in contact with the battery or ignition power wires.
Leaving it hooked up will not cause a problem.
I would pull out the cut off glow plug and see if the tip is still there.
More than once I have read about members driving with the glow plug top being loose or not there when tips break off.
Several have had the broken tips blow out in a very short amount of time, then just screw in a new glow plug.
Just be aware, if you try that, don't let anyone stand on that side of the engine or under the hood while it is running.
Old Oct 23, 2009 | 02:03 PM
xjvince's Avatar
xjvince
I'll have to try blowing it out before I go to the switch.
Do you think a 10 sec. glow time will harm 7 glow plugs?
I'm running motorcraft plugs.
thanks for the help. Vince
Old Oct 23, 2009 | 05:56 PM
Dave Sponaugle
Just minus one plug, you should be fine.
But if you lose one or two more, with a manual button you will have no way to know they burnt out.
That was one of the better features of the new style controller, it told you that a glow plug had burnt out every time you cold start the engine.
The old style system worked off a timer, so it kept on working normally till they were all burnt out and the engine would not start.
Old Oct 25, 2009 | 11:55 PM
xjvince's Avatar
xjvince
well, I pulled the cap out of the broken off glow plug hole, and the broken off tip was gone . I have no idea how long its been gone. don't think it hurt anything. I cleaned out the threads and installed a new one. She fires off better and the glow time is longer. Its a bit short of 10 sec. though. I may play with a manual switch anyhow.
Old Oct 30, 2009 | 09:30 AM
Catsailor's Avatar
Catsailor
I've been having a similar problem with my 94 7.3 IDI. I've checked all GP's and replace one bad one (Autolite) with a new Motorcraft. I have also replaced my fuel return lines and T's. Still slow to start.
I did notice that some of my GP terminal insulators are in pretty bad shape, one is completely gone. Will that affect starting?
Also, what is the best way to test the solenoid and the GP controller to make sure that I am even getting the correct voltage and amperage to the GP's?
Old Oct 31, 2009 | 11:56 AM
Dave Sponaugle
The missing insulators will have no effect on the glow plugs working.
When the relay clicks to turn the glow plugs on, does you volt meter drop several volts?
The contacts in the relay can burn up over time.
The relay still clicks like it is operating but little or no current is going to the glow plugs.
I just replaced my original relay last year for this exact reason.
Old Nov 1, 2009 | 09:04 PM
FORDF250HDXLT
what years use the newer style controller,and where does it indicate that a GP is out? like right in the lite cluster you mean?
would my truck have this?
Old Nov 1, 2009 | 10:21 PM
Dave Sponaugle
87 thru 94 uses the new style controller.
It indicates a burnt out glow plug by short cycling the glow cycle ( less than 10 seconds of wait to start light).
When you have two or three burnt plugs, the relay will no longer try to heat the glow plugs or the wait to start light does not come on just flashes on then back off.
Resendiz
Nov 12, 2015 06:58 AM
juanrodriguez
May 5, 2015 09:05 AM
Toms73
Mar 29, 2015 04:17 PM
jayro88
Dec 2, 2014 08:55 AM
jrstrucks
Apr 22, 2014 11:53 AM
