Sponsored by: Real Truck
Leaking glow plug
Old May 4, 2015 | 09:26 AM
juanrodriguez's Avatar
juanrodriguez
Leaking glow plug
Hello, everyone.
Would/Could a leaking glow plug cause a "hot no start"?
Old May 4, 2015 | 09:27 AM
MisterCMK's Avatar
MisterCMK
Leaking glow plug
What do you mean by leaking? What year is the truck?
Old May 4, 2015 | 09:43 AM
juanrodriguez
Its a 2004 F450.
I use the truck as a weekend 3rd vehicle, and since I bought the truck Ive known its had a leak. Finally, a few weeks ago I took some time to trace it. I knew it was coming from the passenger side and I stuck my head through the passenger wheel well and I saw the glow plug harness where it connects to the plug covered in oil. It was the last 2 plugs only. The first 2 were clean.
I've also experienced a couple times a hot no start, and I'm curious if they could be related.
Old May 5, 2015 | 09:05 AM
MisterCMK's Avatar
MisterCMK
That is not going to be your hot start issue. There are o-rings on the harness that is causing that leak.
Your hot start issue is probably a high pressure oil leak.
juanrodriguez
Dec 14, 2015 10:27 PM
jrstrucks
Apr 22, 2014 11:53 AM
Blowinsmoke
Sep 1, 2009 02:44 PM
dogdude2003
Mar 2, 2006 09:27 PM
RedRage
Nov 30, 2004 10:16 AM
