Front tow hooks
I like this idea... I need to do some thinking on this concept because I'd love to have a good set of tow hooks on the front.
I'm thinking you could weld/bolt some pieces from the frame rail and make them come out below the bumper a couple inches. That way they would also double as a little step.
...Us short guys need all the help we can get right?
on
The problem with any type of bracket attached below the frame is the leverage when pulled could bend the frame. The link that Jose linked first is a good example of what I would consider a bad example. The Second link is a good way to do it. You need to have a straight pull on the frame to avoid bending anything.
A hook attached directly to the frame is your best bet or the receiver that ties both frame rails together is good too. My snow plow frame works for me. I think I will be attaching a receiver tube to it so I can use that with a shackle and a front tow ball.
you can see here how HUGE the plow frame brackets are picture is in from the driverside wheel well. I think even though to hang down they spread the load over enough frame to not hurt. I figure if they can holed a 900 lbs plow and push who knows how much snow in front of the 10 foot blade (9 ft scoop) then I can use it to yank heavy loads.
And here just above the Blizzard sticker is where I would mount a receiver
coopster17
09-10-2015 09:59 PM
greg213187
03-02-2010 06:08 PM
