Battery icon Flashing
Old Oct 20, 2009 | 08:59 PM
Xcaliber's Avatar
Xcaliber
Hello guys. I have a sport trac 2005. The problem is when I press my accelerator, the battery icon comes out onthe dashboard. I have bought a new battery although my battery is still in great shape i suppose because the mechanic said so. But i know that if you look at the battery sight the float is already yellow. Soooo, what do you think is the problem?
Thanks.
Old Oct 20, 2009 | 09:09 PM
aquanaut20's Avatar
aquanaut20
Thanks.
I think you need a new, honest mechanic who know how to use a VOM.
12.5vdc battery voltage at rest
14.5vdc Charge at 2000rpm
I would be checking the brushes and commutator in the alternator.
Old Oct 20, 2009 | 09:59 PM
steve(ill)'s Avatar
steve(ill)
probably the alternator. normally last about 100k miles, but can go earlier. the mechanic should be able to diagnose that. takes about 5 minutes to figure it out.
Old Oct 20, 2009 | 10:21 PM
shorod's Avatar
shorod
I'd say it's pretty rare for a bad battery to cause the "charging system" indicator to illuminate. As both replies above suggest, the problem is likely the alternator. Likewise, a simple check of the charging system voltage during a start condition and with engine running should indicate pretty quickly where the problem likely lies.
-Rod
jdafonte
Jan 20, 2024 02:16 PM
SoCalAngler
Modular V10 (6.8l)
Nov 12, 2016 05:00 PM
Tenvol1968
Modular V10 (6.8l)
Sep 5, 2014 10:45 AM
tjc transport
Modular V8 (4.6L, 5.4L)
Nov 29, 2008 06:21 PM
