78 Axle ID help..
Old Oct 20, 2009 | 04:38 PM
Action4478's Avatar
Action4478
78 Axle ID help..
I have a 78 F250 that I was going to sell (until a spark plug broke off in the left head ) .. I am now going to part it out . I need help identifying the axles (no tags ) , any help would be appreciated, thanks ....
Old Oct 20, 2009 | 05:34 PM
75F350's Avatar
75F350
Do you have any pics of the axles. The F250 will have a Dana 60 out back, and probably have a Dana 44 up front.
The dana 44 will have ball joints and not king pins.
Quick set of pics will make it easy to identify.
Just gotta ask about parting a truck due to a busted spark plug. Thats kind of like throwing the baby out with the bath water isnt it?
Spark plug removal seems to be a much easier solution to scrapping out an entire truck.
You can fix the head by removing the plug?
Old Oct 20, 2009 | 05:49 PM
Action4478's Avatar
Action4478
Its not in very good shape . Tires are new , L F door Is new , Other than that it would have been a truck to leave at the cabin to plow the drive , I'll get some pics ...The motor ran great till it fouled a plug from idling to long . I have 4 of these , this one was purchased for a back up plow truck , until I bought my power stroke . BTW, It has ball joints
Old Oct 20, 2009 | 06:05 PM
Action4478's Avatar
Action4478
Old Oct 20, 2009 | 06:07 PM
Action4478's Avatar
Action4478
Sorry about the pic from the side ....
Old Oct 20, 2009 | 07:38 PM
75F350's Avatar
75F350
Nice enough old truck. That is a dana 44 front, it is a high pinion with open knuckles and disc brakes. It is an 3/4 ton version that sports 8 lugs.
The rear is a run of the mill dana 60. It is a full floater with 30 spline axles and drum brakes.
That should cover it. You will have to remove the diff covers to verify the ratio.
Old Oct 21, 2009 | 07:54 AM
Action4478's Avatar
Action4478
Thanks for your help ...
Old Nov 5, 2009 | 09:38 PM
donnor's Avatar
donnor
Front dana 44 available?
If proceeding with the parting out, is the Dana 44 still available and, if so, at what price?
dn.
Old Nov 5, 2009 | 11:47 PM
highboyman's Avatar
highboyman
Is it a 4 spd or auto?
