parasitic power draw
Old Oct 20, 2009 | 10:20 AM
tjc transport's Avatar
tjc transport
i ain't rite
on one of the 99 crown vics, i am getting .58 amps draw with everything turned off.
does this sound like a bad diode in the alternator??
if left sit for 2 days, it will kill the battery.
Old Oct 20, 2009 | 01:40 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Most all vehicles today have SOME current draw with everything off. Computer, radio (to maintain station selection), etc. Don't know HOW much. but a 1/2 amp is prob close to right. How old are (is) the batteries (battery).
Old Oct 20, 2009 | 04:17 PM
tjc transport
i ain't rite
all 6 batteries i have are less that 6 months old.
i do not test with a battery hooked up. i got the .58 amp draw with the amp meter hooked up between the pos cable and the pos terminal on a fully charged battery.
initial draw is .96 amp, then once the computer and radio are done with the surge i get the .58
that seems like a very high draw though. i was figuring on more like a .002 amp draw.
Old Oct 20, 2009 | 04:37 PM
JimsRebel's Avatar
JimsRebel
.58 amps might be a little high but I dont really know. I would disconnect the large wire on the ALT while watching the amp meter to see if it lowers the current draw. It could also be the voltage reg. so you might try disconnecting it also.
Jim
Old Oct 25, 2009 | 10:25 AM
megawatt00's Avatar
megawatt00
To see of it is the diode Tom feel the alt in the morning. If it is a tad warmer than the air temp chances are the diode is the culprit. This is the poor mans test.
Old Oct 25, 2009 | 01:40 PM
tjc transport
i ain't rite
thanks for the tip Jim. but i eliminated the alternator as the culprit today, when i unplugged it and got no change.
the trunk light switch was bad. unplugging the trunk light brought the drain down to .31 amps.
300 milliamps is a lot better, but i think i still have another light staying on. i am thinking it should be more like 50 or 100 milliamps shut off.
Rose Clifford
18
Feb 8, 2011 09:56 AM
Alfster
Sep 11, 2007 09:42 AM
Scoarch
Jun 18, 2005 08:20 PM
TaosCowboy
Dec 7, 2004 05:03 AM
Mil1ion
Jun 18, 2002 01:51 PM
