Modular V10 (6.8l)
TECH folder
Old Oct 20, 2009 | 08:55 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
TECH folder
This is the Ford V10 6.8L Tech folder.
Please read the "Taking submissions for the TECH folder" and post your suggestions for links to threads with pertinent information.
Old Oct 20, 2009 | 08:56 AM
krewat's Avatar
krewat
Wondering why your MIL doesn't come on? Or in other words, wondering why your truck doesn't have an O2 sensor after the catalytic converter or a bunch of other weird things, like why your state can't do an emissions inspection?
https://www.ford-trucks.com/forums/5...t-come-on.html
Changing exhaust studs, removal of broken ones, etc
https://www.ford-trucks.com/forums/8...t-it-info.html
My own thread about removing studs and installing eBay headers:
https://www.ford-trucks.com/forums/s...d.php?t=593174
Thread on y-pipe, and lots of comments from people who actually did it:
https://www.ford-trucks.com/forums/6...h-results.html
And more y-pipe threads to read:
https://www.ford-trucks.com/forums/4...s-y-pipes.html
https://www.ford-trucks.com/forums/6...t-flutter.html
Clean your MAF
https://www.ford-trucks.com/forums/s...=1#post8490555
For pictures of MAF removal and a procedure, look at the Volant CAI install thread at:
https://www.ford-trucks.com/article/..._F250_V10.html
Volant CAI installation on a 2-valve 2001 V10:
https://www.ford-trucks.com/forums/7...-2001-v10.html
Superchargers:
https://www.ford-trucks.com/forums/5...g-whipple.html
A 3V in a 2V truck:
https://www.ford-trucks.com/forums/8...ue-solved.html
Synthetic oils:
https://www.ford-trucks.com/forums/8...hetic-oil.html
Replacing a V10 - lots of great info about E-series vs. F-series engines, 2-valve
https://www.ford-trucks.com/forums/9...2000-f350.html
A note about 2004 and 2005 2-valve PCV valves and gas mileage
https://www.ford-trucks.com/forums/9...cv-valves.html
Hedman header install, thanks to ak-angler
https://www.ford-trucks.com/forums/1...ll-w-pics.html
Some great COP info, from devongarver
http://mustangforums.com/forum/6314454-post1.html
The perennial plug-change discussion thread.
https://www.ford-trucks.com/forums/1...ead-heads.html
Old Oct 20, 2009 | 09:26 AM
krewat's Avatar
krewat
Old Sep 22, 2010 | 09:29 AM
krewat's Avatar
krewat
Spark plug thread and factory procedure changes.
After much hemming and hawing, I have decided to put this info in the tech folder. This is from a document that Ford provided to the NHTSA a few years back in 2005 in response to an investigation that was closed by the NHTSA because it was not deemed a "safety" issue. It was reviewed again in 2007 and again deemed to not be a safety issue because of the number of complains (total of 652 by 2007) versus the number of engines total (over 10,000,000).
My review of documents related to this (which I won't include here) show that after the model-year 2002 changes to a long-thread head, the 2003-2004 model-year shows a substantial reduction in plug blowouts. Of 652 complaints, NONE were shown to cause any damage to the hood, cause a fire, or a gas leak of any kind. Stalling was possible but again in very rare cases, and a restart was usually possible except in ONE case.
Running spark plug changes:
December 1996 - 4.6L 4V alignment feature added
February 1997 - 4.6L 2V head alignment feature added
September 2000 - WEP (Windsor Engine Plant) 2V head alignment feature modified (4.6/5.4/6.8)
November 2002 - WEP introduced long thread heads on 2V (all)
May 2003 - REP (Romeo Engine Plant) introduced long-thread heads on 4V 4.6 and 5.4
November 2003 - REP introduced long-thread heads on 2V and modified alignment feature
In 1999, and 2001, an interim fix was done for a cross-threading issue.
Original process:
Step 1 - Zero torque spark plug (air tool)
Step 2 - Torque to 16-20Nm final torque (DC Run down), monitor at 6-12Nm, and final torque must be reached within 0-360 degrees.
New process (addressed the possibility of applying installation torque for more than 25 degrees of rotation)
Step 2 - Torque to 16-20Nm final torque (DC Run down) start monitor at 6-12Nm, and final torque must be reached within 3-25 degrees.
Another action to address cross-threading was the addition of an alignment feature to lead the plug into the hole.
Old Feb 14, 2013 | 09:17 AM
krewat's Avatar
krewat
AFTERMARKET PART NUMBERS AND TECH INFO
Whipple supercharger belt part #'s, thanks to green250
whipple belt part # - Ford Truck Enthusiasts Forums
Old Mar 21, 2016 | 07:53 AM
krewat's Avatar
krewat
Blown plug fixes
An excellent Timesert how-to with pictures, by tmehrkam
https://www.ford-trucks.com/forums/9...th-photos.html
Nominated for the tech folder by Wolfboro - THANKS!!!
Old Mar 13, 2021 | 04:39 PM
krewat's Avatar
krewat
How to quickly tell if an engine is a 2 or a 3-valve V10: https://www.ford-trucks.com/forums/1...ifference.html
ReddTruck
2004 - 2008 F150
15
Nov 17, 2019 03:29 PM
djousma
6.7L Power Stroke Diesel
23
Sep 28, 2019 07:00 PM
ejgford
Modular V10 (6.8l)
Oct 5, 2011 05:45 AM
tackleberry23
Dec 2, 2008 12:42 AM
