wheel bearing torque
Old Oct 20, 2009 | 02:31 AM
clhart426's Avatar
clhart426
1978 f150 4x4 i just did the upper and lower ball joints on both sides and the ujoints on the axel...and ive goto drive it to work tommorow at 9am...im stuck at how tight to tighten that wheelbearing nut...so after i do that i just have to throw the locking hubs back together and il be good...BUT HOW TIGHT DO I TORQUE THOSE BEARING NUTS????
and another ?--does another years stearing gear fit my truck??
Old Oct 20, 2009 | 11:24 AM
MT-F250's Avatar
MT-F250
Iv'e been told to tighten it until there is some drag on the wheel when you spin it by hand then back off the nut just enough to get rid of the drag, maybe about a 1/4 turn.
Someone smarter than me might have better info.
Old Oct 20, 2009 | 11:36 AM
77h0t_r0d_wrecker's Avatar
77h0t_r0d_wrecker
When I do wheel bearings on any vehicle, I tighten the nut ALL THE WAY until I can't move the wheel. I do this to make sure the bearings are seated in the races. Then I back off a few threads, spin the wheel. I repeat that a couple times until the wheel has a good amount of drag, but spins freely. I can't really explain the proper amount without showing you though...
Basically you don't want the bearing too tight that you can't spin the wheel easily, but you don't want it too loose that you can move the nut by hand. Hopefully this post helps!
Old Oct 20, 2009 | 02:58 PM
clhart426's Avatar
clhart426
well im going to try both of what you guys said, bc it seems about the same thing. thanks
Old Oct 21, 2009 | 01:06 AM
Tees77f150's Avatar
Tees77f150
If I remember correctly, it is 25, or 30 foot pounds, and then back off the nut a half turn. thats from the shop manual for a 1977 2wd and my memory.
Old Oct 21, 2009 | 01:34 AM
jhooch's Avatar
jhooch
It's definitely a feel thing. Not too loose and not too tight. Actually Ford service manual says to torque inner nut to 50 ft-lbs, while rotating wheel back and forth to seat bearings. Then back nut off 90 degrees. After installing lock ring, install outer lock nut and torque to 50-80 ft-lbs. Hope this helps.
Old Oct 21, 2009 | 10:05 AM
shanes66charger's Avatar
shanes66charger
This is what I did when i redid my D44 and have had no issues.
Old Oct 21, 2009 | 10:45 AM
460/5's Avatar
460/5
Zombie Survivalist
i tighten mine till i have to use both hands to move the rotor. then i back off about a half a turn; just enough so that i can move it with one hand fairly easily but as soon as i let go it stops. then i torque the crap outta the lock nut. not sure if thats right, but it works! lol.
Old Oct 21, 2009 | 01:18 PM
Tees77f150's Avatar
Tees77f150
Autozone, I was just looking at and they say 17-25 ft lbs, while spinning the tire, then back off 1/2 turn and then retighten to 10-28 inch lbs. Now again, this is for a 2wd. My shop manual on cd is giving me a fit.
Old Oct 21, 2009 | 05:59 PM
jhooch's Avatar
jhooch
2WD is completely different than 4x4.
Old Oct 21, 2009 | 08:41 PM
Tees77f150's Avatar
Tees77f150
I think we noticed that!
Cyrusjohn
May 6, 2017 09:24 PM
jstihl
Jan 29, 2016 10:11 AM
daisyman
Jan 12, 2016 02:33 PM
genscripter
Nov 16, 2012 07:56 PM
brucebowker
1983 - 2012 Ranger & B-Series
17
Jul 3, 2011 06:37 AM
