Squeaking on right turns only?
Old Oct 20, 2009 | 03:33 PM
berry1234's Avatar
berry1234
My 78 F250 4x2 has been squeaking more and more on right hand turns. The brakes are in perfect shape and it sounds like it's coming from the front left, but hard to tell. Could this be the sound of bad wheel bearings?
Old Oct 20, 2009 | 03:37 PM
montana_highboy's Avatar
montana_highboy
Power steering pump?
Old Oct 20, 2009 | 03:44 PM
berry1234's Avatar
berry1234
No, pump is fine. It sounds like a metal on metal sound. Similar to brakes, but dryer if that makes sense?
Old Oct 20, 2009 | 05:12 PM
75F350's Avatar
75F350
Typically this sound is common with bad wheel bearings. When a load is applied to the bearing, like during a turn, the forces create a noise. During straight line driving, the bearings can share the load, and the noise is not as loud.
My guess is that you have a wheel bearing that is on its way out.
Have you jacked the truck up to see if the bearing / hub is loose?
Old Oct 21, 2009 | 12:32 PM
berry1234's Avatar
berry1234
I did on the right side, not on the left. I will do this. I had the rear axle/brakes inspected a while back and the bearings looked new, but I never checked the fronts.
Old Oct 21, 2009 | 02:40 PM
460/5's Avatar
460/5
Zombie Survivalist
yeah. it'll squeak for awhile like that. if it starts clunking though, the bearing is done, so drive it as minimally as possible till it gets fixed after that. id get on that ASAP though, if it is the bearing, which it very much sounds like it is.
Old Oct 21, 2009 | 09:18 PM
Tees77f150's Avatar
Tees77f150
That is what I would say it is also, they are not very expensive to replace, and a breeze to do.
broncoderek
Oct 28, 2014 02:54 PM
HighRiskJob
1997 - 2003 F150
Sep 16, 2014 09:22 AM
pastelsand
Aug 29, 2014 11:09 PM
No_Rulz25
Jul 14, 2014 07:39 PM
AkF250HD
Aug 7, 2013 06:31 PM
