Coolant filter question
Old Oct 21, 2009 | 06:35 PM
69cj's Avatar
69cj
Bought the Zerex GO-5 today. $10.49 at Napa. Dealer wanted $21.99 for the premium gold. Same specs on the containers.
Old Oct 21, 2009 | 09:56 PM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Originally Posted by EddieEX10
I installed this same filter two weekends ago. Took me about an hour. Nice good with good instructions. I ended up cutting the heater hose connections short on 1 side and had to get some extra heater hose to repair. No big deal but try and avoid my mistake when you install.
How did you do that???
You just make one cut and install the "T" into this "one cut"???
How can you make it "short????
No reason to remove any length of hose while installing.
Old Oct 22, 2009 | 06:15 AM
EddieEX10's Avatar
EddieEX10
My excursion only had 3-4 inches of hose between the connectors at either end.
I needed to cut the hose exactly in the middle to be able to fit the T in place and have enough hose on each end to clamp
I forgot the old measure twice cut once rule...
Old Dec 5, 2009 | 05:21 PM
bkvanbek's Avatar
bkvanbek
I got the Dieselsite coolant filter kit, but it will not fit where it was designed for. Because of my Banks inter-cooler tube. Does anyone know how else to mount it?
Old Dec 5, 2009 | 05:30 PM
Beachbumcook
Got Diesel?
The Dieselsite coolant filter was designed for an OEM application... so with your Banks intercooler, I guess you will have to design your own kind of bracket and doublecheck to ensure that the hoses included (or buy new ones) so you can install.
The coolant filter can go anywhere, but obviously keeping the hose lengths short, simple and clean (to make the install look good) is key.
I am assuming you will need to fashion your own kind of bracket to connect to "somewhere" and then connect it to the Dieselsite "head unit"... hopefully leaving room to srew and unscrew the filter after it is installed (so you can safely and easily change it).
Good luck and provide pictures when you figure it out.
Thanks,
Old Apr 11, 2010 | 02:56 PM
Scottie055's Avatar
Scottie055
Re: Banks IC, just cut the Dieselsite bracket in half, drill two holes in bottom of bracket on each half and bolt together, buy a 3in bolt for the sleeve and cut the sleeve to size, line up the bracket and mark and drill a hole on the Banks IC support. Just installed mine last night. I know this thread is old but thought this might help someone. I don't have pictures right now but if someone wants them I can take some.
Old Apr 11, 2010 | 03:05 PM
rickatic's Avatar
rickatic
I used the same kit. 45 minutes to install. Good advice on the ball valves an a couple of extra filters. My first filter went 350 miles and was plugged solid. Second went about 1000 and the third has went 4000 miles and is still good.
Old Apr 11, 2010 | 03:11 PM
bkvanbek's Avatar
bkvanbek
I cut two thirds of the bracket off, just keep a flat piece. drilled a couple new holes and mounted it to the radiator mount.
How do you know when it is plugged?
Old Apr 11, 2010 | 04:56 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
I watch the flow back into degas bottle while the truck is running. I turn my valve to the line running to the degas bottle on and off.
Old Apr 11, 2010 | 05:19 PM
rickatic's Avatar
rickatic
x2 on the degas return line
Old Apr 11, 2010 | 05:28 PM
amdriven2liv
Also, check out this members album. Neat sight glass He put in.
Ford Truck Enthusiasts Forums - MoyockPowerstroke's Album: Coolant Bypass Filter
Old Apr 11, 2010 | 05:34 PM
rickatic's Avatar
rickatic
yes, I have seen that sight glass. Very cool, came from McMaster-Carr
coolfeet
Jan 1, 2021 10:36 AM
hi-jacker
Oct 27, 2014 02:26 PM
El_Coqui
Sep 6, 2014 11:06 AM
mjlevi
Oct 10, 2006 04:54 AM
