burning up computer
Old Oct 18, 2009 | 10:23 PM
ford to the bone's Avatar
ford to the bone
ford to the bone
burning up computer
what could be burning up the cumputer
Old Oct 18, 2009 | 10:27 PM
RubberDuck's Avatar
RubberDuck
Without more info on what's happening, it's hard for us to tell you. Tell us what exactly is happening.
Old Oct 18, 2009 | 10:39 PM
ford to the bone
ford to the bone
put a new computer in four days ago it funs fine for a couple days then all the lights in the dash comes on and it dont want to run
Old Oct 18, 2009 | 10:49 PM
RubberDuck's Avatar
RubberDuck
Is it raining, water a possibility? I would pull the connector at the fenderwell and check every pin looking for burnt pins. Above that, it sounds like you've got a bad short somewhere. I would check all connectors coming to and from the computer. That's the best I can tell you at this point. I've never encountered this problem. Hopefully someone who has will chime in. But I will say, I've never seen this before.
Old Oct 18, 2009 | 10:51 PM
ford to the bone
ford to the bone
i never have nether
Old Oct 18, 2009 | 10:54 PM
RubberDuck's Avatar
RubberDuck
Do you have a chip on it? Any mods?
Old Oct 19, 2009 | 05:21 AM
ford to the bone
ford to the bone
no not that i know just bought it
Old Oct 19, 2009 | 06:34 AM
MADVAN's Avatar
MADVAN
Iam with duck.
Intermittent short or a over voltage spike from
a bad regulator. Over voltage is rare and tends to be AC not DC.
Also a +12v leak into the +5v side of the pcm will do it. (wiring rubout short)
Same stands true for the high idm inj voltage into the pcm.
Will a scan tool read after the failure?
What made you change the pcm the first time?
Bill
Old Oct 19, 2009 | 07:04 AM
ford to the bone
ford to the bone
a friend told me that it was the pcm so i got on then it was fine for a couple days about the scan tool i never tried because dont have one
Old Oct 19, 2009 | 07:55 AM
RubberDuck's Avatar
RubberDuck
Okay, so lets back up. Where is the "pcm" you replaced? Is it on the fender in the engine bay, or is it in the firewall behind the parking brake. And did YOU replace it, or did someone else. Just trying to fill the gaps.
Old Oct 19, 2009 | 08:16 AM
ford to the bone
ford to the bone
on the firewall
Old Oct 19, 2009 | 08:37 AM
ford to the bone
ford to the bone
and i changed it
Old Oct 19, 2009 | 08:48 AM
Hussler's Avatar
Hussler
I wonder if it's just the CPS going out. When it happens and you crank the engine over does the tach move at all?
Old Oct 19, 2009 | 09:38 AM
ford to the bone
ford to the bone
yes the tach moves when turning over
Old Oct 19, 2009 | 10:08 AM
MADVAN's Avatar
MADVAN
Does the WTS and CEL lamps in the dash cycle on then off?
If the tach works what leads you to believe the PCM is burned?
Just a friend told you or he checked it?
Bill
