Want remove emission and useless out in Bronco with 5.0L
Old 10-17-2009, 10:32 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150
Milwaukee1979F150 is offline
I apologize for make another threads but I was try get more info.
It 91 Bronco 5.0L with Aod
What stuff can I remove and get good economy or power? I would like keep fuel injector.
Erg valve? Can I remove or it important part to have? Since Erg tube is rot and leak.
What about canister can I remove?
what about tons of vacuum hoses which one I can remove it?
Remove cat convector and replace stock exhaust manifold with long tube header that came from 67 cougar. How can I hook oxygen sensor to 2 headers or could put on one header? Does it would affect fuel economy?
Is anything I forgot to add this then please add so I be happy to check.
Old 10-18-2009, 08:01 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
I don't think those headers will work. Changing the exhaust is a good idea though.
The EGR valve actually increases fuel economy.
Removing any of that stuff will not really give you much if any gains.
The truck will probably run the best, if you just fix what is broken.
Old 10-18-2009, 09:47 AM
Milwaukee1979F150
Problem with replaced heads have EGR block by preview owner who put helicoil in that so I can't use EGR system again if I use that heads.
Original heads on that bronco is bad it have valves sticky and valve seals crack.
Old 10-19-2009, 01:58 AM
TexasGuy001
I guess you won't be able to hook everything back up. If it were mine, I would use heads that weren't blocked off.
You can go that route, but you will need the EGR eliminator module so the check engine light will stay off. I believe that is the only way to do it.
Old 10-21-2009, 10:42 PM
alxsnmr's Avatar
alxsnmr
alxsnmr is offline
The EGR eliminator can be used or you can block the intake port and let the computer stay with egr operating since that system doesn't know if it is flowing. You can just weld an HEGO bung to the exhaust pipe behind the headers, or fit it to one header only and weld it in. I think it was Conanski that stated he runs headers with only the one side having the HEGO in it without issue. You will have to leave the TAD and TAB in place but you can remove the vacuum lines feeding them as well as the AIR system if you really want to clean it up. The biggest drag from the emissions system is when the AIR pump begins to fail...
southernmudder
09-26-2014 03:00 PM
Chuggster
1999 to 2016 Super Duty
11-13-2010 08:50 PM
hogdawg77
04-05-2010 01:11 PM
jlutes
04-29-2009 11:00 AM
Dusty_F150
1983 - 2012 Ranger & B-Series
05-29-2007 08:08 PM
Quick Reply: Want remove emission and useless out in Bronco with 5.0L
