I am assembling my motor after a having the block bored and a valve job done. Assembly is done to the rocker arms. I am using a Haynes manual for guidance, and am having trouble following the valve lash procedure.
The book says with #1 at compression TDC check lash on both #1 valves and #5 exhaust and #7 intake.
The #1 valves are closed and I can do the check, but #5 and 7 are open so the check cannot be done.
Do I have the cam and crank out of phase? or what am I missing?
Can some one with experience please help me, Thanks in advance
Assuming this is a late model motor the heads have pedistal mount rockers and there is no lash adjustment so there's no point measuring it. If you did have adjustable rockers the sequence followed depends upon the engine firing order, what is it on your motor?
Yes this makes sense, but the valve lash should not have changed unless the block or heads were decked, and you won't get accurate numbers unless the lifters are pumped full of oil.
For that firing order the measuring sequence is..
With piston #1 @ TDC, check #1 In/Ex, #4 In, #3 Ex, #8 In, #7 Ex.
With crank rotated 180 deg from above, check #3 In, #2 Ex, #7 In, #6 Ex
With crank rotated another 270 deg, check #2 In, #4 Ex, #5 In/Ex, #6 In, #8 Ex.
Thanks Paul, This makes more sense to me, but I won't be able to see the engine until tomorrow now. Just to make sure I did things right, with the crank an cam installed (no heads yet) I brought #1 piston to the top of its travel, then intalled the timing set with cam gears dot at the bottom on verticle centerline and the crank gear dot at top on verticle cl. This should have set #1 piston at TDC compression stroke, right?
Hli Doug, well that eases my mind. It is kind of disconcerting to follow a procedure set out in a manual only to find it doesn't match the engine you're working on.
My Haynes manual covers Ford pu's 1980-96, do you know when the firing order was changed? What is the new order if you know it off hand? Thanks, Fred
The firing order changed in 1994 when the truck motors got the F4TE roller cam, and the "new" order is the 5.0HO/351 version that is on the decal under the hood of your truck. That does not make your 5.0 a HO though. And don't sweat the discrepencies in the Haynes manual, all basic assembly and maintenance procedures are common regardless of the firing order.
