Zero lash valves?
Old Aug 17, 2008 | 10:29 PM
Dan Edick's Avatar
Dan Edick
Question Zero lash valves?
Hey guys its been a while, but i'm buying a new timing chain gasket set for my 223. It says 223 : with zero lash valves, or 223: with out zero lash valves. My truck is a 64 and how can i tell if i have zero lash valves or not?
Old Aug 17, 2008 | 10:46 PM
85e150's Avatar
85e150
My WAG: "zero lash" = hydraulics, the others are solids.
If a better mind doesn't clarify or correct, check for other evidence of this.
(lifter part numbers matched up to the timing set or whatever....)
Old Aug 18, 2008 | 08:16 AM
JimKoz's Avatar
JimKoz
As far as I know, zero-lash rocker arms were only installed on passenger car engines during the last few years of 223 production. I think they were trying to achieve quieter operation and lower maintenance without re-designing the
engine for hydraulic lifters.
Take off the valve cover and inspect the rocker arms. If they look like conventional rockers, then you don't have a zero-lash engine. A zero-lash rocker arm has a hinged cam at the end of it that contacts the valve stem, and a spring-loaded plunger that rotates the cam until takes up the valve lash.
I think that the zero-lash engines also had a different camshaft and an extra water hole in the block that the truck water pump won't cover up, but I wasn't aware that there was a difference in timing cover gaskets.
Old Aug 18, 2008 | 06:52 PM
Dan Edick's Avatar
Dan Edick
who knows, but my truck definetly doesnt have zero lash rockers. Thanks man :]
mOROTBREATH
32
May 22, 2017 12:56 PM
78 & 87 Super Cab
Apr 27, 2015 06:09 PM
C-700
May 28, 2014 10:32 PM
jdasilva644
Oct 15, 2010 11:13 PM
Argess
Sep 26, 2009 02:47 PM
