4.9 throwing fan belts
Old Oct 17, 2009 | 06:54 PM
volks's Avatar
volks
I just bought this truck. 1991 F250 4.9 4wd , 5 spd w code trans 3.55 gears.
Everything works like a charm , but it has tossed 2 new belts in 3 weeks. The p/s pulley has maybe 1/16 play front to back and the idler assy is canted just a shade to the lower front. All other pulleys are snug and visually in line. I am snookered here. Going to throw a complete idler assy at it and go from there.
Anyone have any idea's?
Thanks, Volks
Old Oct 17, 2009 | 07:22 PM
quicklook2's Avatar
quicklook2
water pump bearing may be bad.
Old Oct 17, 2009 | 07:39 PM
Eddiec1564's Avatar
Eddiec1564
That idler being canted will throw a belt everytime. Also check to make sure the pulleys have the same number of ribs on them. I got a alternator from a parts place and it had one less rib, that caused the belt to tear and fall off. I went back but they already sent the core out. Went to the junkyard and found another proper pulley and put on.
Old Oct 17, 2009 | 07:41 PM
wolfsmurf's Avatar
wolfsmurf
going in the right direction with the tentioner. the rotator shaft of it usually will wear to the point of letting the arm stick out of alignment and kick the belt off. if that does not fix it start looking for broken brackets as in alternator/powersteering brackets.
bulla
38
Jul 16, 2019 03:02 PM
texansport
2004 - 2008 F150
Sep 5, 2015 08:42 PM
X-70STANG-F150
1997 - 2003 F150
Nov 26, 2014 06:37 AM
WB4IUY
Escape & Escape Hybrid
May 31, 2014 06:47 PM
8e3k0
6.4L Power Stroke Diesel
Mar 15, 2014 08:22 PM
