once again, maf conversion
Old Oct 17, 2009 | 02:35 PM
fe8u's Avatar
fe8u
i found a 95 f150 5.0 maf truck that has a hog0 computer i do believe this also will control a e4od? can i make this work on a 95 5.8 f150 with e4od
by changing the injector order?
thanks for the help
Old Oct 17, 2009 | 03:53 PM
rla2005's Avatar
rla2005
That should work. Ford Fuel Injection EEC Program Codes
Old Oct 17, 2009 | 04:16 PM
lew52's Avatar
lew52
The 95 5.0 and the 95 5.8 should have the same injector order ...
Old Oct 17, 2009 | 07:59 PM
fe8u's Avatar
fe8u
ok so if i grab the computer and harness, mafs ,intake tubing what else should i be looking at to use on my 95 f150 ?
are there any good reads on doing this conversion
my plan is read up over the winter and try something this coming summer
Old Oct 17, 2009 | 11:58 PM
rla2005's Avatar
rla2005
I was of the same opinion too when answering this thread. But I found conflicting info at several sites:
1995 Ford Firing Orders
WikiAnswers - What is the firing order for a 1995 Ford F-150 5.8L
Read through this thread: FullSizeBronco.com - 78 - 96 Ford Bronco offroad club, forums, tech, installs
I suggest you find a good shop manual or someone with a 1995 F-series with a 5.0L to confirm it's firing order.
Old Oct 18, 2009 | 03:38 AM
lew52's Avatar
lew52
I know the 95 is a roller mass air motor with sequential fuel injection , so it has the same firing order as the HO and 351 . I did the HO swap in my truck and it was a direct swap . I think some of the early 302 rollers had the 302 firing order, not sure what year they changed....Lew
Old Oct 18, 2009 | 07:21 AM
EPNCSU2006's Avatar
EPNCSU2006
'94-up 302s should use the 351 firing order. Double check that the transmission is actually an E4OD behind the 302. Many of the later model 302s were paired with a 4R70W automatic.
Andy94351
Apr 1, 2022 12:08 AM
SmokeBlower
52
Feb 9, 2012 09:13 PM
Monsterpony557
13
Jan 1, 2010 10:57 AM
fossman1
Engine Swaps
18
Oct 23, 2008 04:54 PM
termyt00
Aftermarket Products
Feb 1, 2005 10:51 PM
