Help, stuck in Idaho
Old Oct 17, 2009 | 09:38 AM
puller45's Avatar
puller45
Anybody know codes 0603 or 0678 ?
Old Oct 17, 2009 | 09:50 AM
Pocket's Avatar
Pocket
0603 is caused by your Edge, and is normal.
0678 is Glow Plug #8 failure. That wouldn't keep your engine from running.
What's happening with your truck? Tell us what it's doing.
Old Oct 17, 2009 | 09:59 AM
puller45's Avatar
puller45
It's not my truck, 2003 7.3, 4 inch exhaust, superchips setto stock. No power,heavy smoke, idles fine.
Old Oct 17, 2009 | 10:02 AM
rbaker6336's Avatar
rbaker6336
0603 Powertrain Control Module Keep Alive Memory (KAM) Error
0678 Cylinder 8 Glow Plug Circuit
Too slow
Old Oct 17, 2009 | 11:13 AM
puller45's Avatar
puller45
EBPV stuck partially closed,it had been disconnected by po and worked it's way closed. Stealership in Pocatello was able help and let us watch.
Old Oct 17, 2009 | 11:32 AM
Layson's Avatar
Layson
Post up on here, maybe someone local can come help you out.
Diesel Bombers - Idaho Bombers
Old Oct 17, 2009 | 12:40 PM
puller45's Avatar
puller45
BAck on the road, using my phone to post it's a pita, I will expand when I get backto my laptop. Thanks for the replies.
Old Oct 17, 2009 | 12:52 PM
Kwikkordead's Avatar
Kwikkordead
Worked it's way closed????
There is a spring inside the pedastal that is supposed to hold it open.
It's a "fail safe" part of the design.
Old Oct 17, 2009 | 01:10 PM
gtnwood's Avatar
gtnwood
Lucky u werent stuck in Deetroit instead
Old Oct 17, 2009 | 08:52 PM
mechelement's Avatar
mechelement
Where in Idaho are/were you stuck?
Old Oct 18, 2009 | 08:49 AM
bfife's Avatar
bfife
still plays with trucks
there are lots worse places to be stuck!
Old Oct 18, 2009 | 10:33 AM
SuperDoodie's Avatar
SuperDoodie
You mean www.idahodieselpower.com
Old Oct 24, 2009 | 11:03 PM
puller45's Avatar
puller45
All I know is what I saw, the Mechanic had to use a hammer and long screwdriver to open the valve which had apparently found a way to close itself. The truck ran fine after he did it. I watched the whole process. When he got the valve open, he reattached the solenoid and pulled the plug so it would not try to close again. My friend (the owner) has never heard the jet engine sound we all know and love, so the valve has not worked since he has owned the truck.
Old Oct 24, 2009 | 11:14 PM
jkidd_39's Avatar
jkidd_39
hehe.. don't break down in Cheyenne WY.. you got lucky!
Old Oct 24, 2009 | 11:22 PM
puller45's Avatar
puller45
To all who answered my call, I thank you. My phone (or rather my challenged fingers) limited my abilitiy to reply in a timely fashion. Courtesy Ford,The Ford dealer in Pocatello Idaho that happened to be about two blocks from where we were stranded, is top-notch in my book, they got us in right away, diagnosed the problem by our description, and had us back on the road in about an hour. We were not told that we could not be in the shop area, and in fact were able to watch and assist. I hope I don't get any one in trouble here, but I want to give credit where it's due, in my opinion this is not a "stealership" but rather a honest shop that at no time tried to gouge us. We finished a semi successful hunting trip (two deer for four hunters) in southeast Idaho, and are back home.
