carb problems
Old Feb 21, 2017 | 03:09 PM
mkhmann's Avatar
mkhmann
carb problems
I have a 1984 f150 with a 351w. I rebuilt the carb as i had some leakage in the pump ***. Rebuilt carb(2150 with pollution parts). Installed on manifold. Started engine and carb flooded out. Removed air horn assembly. Started up and gas was bypassing float because gas pressure was to high. Replaced fuel pump and had same problem. I checked fuel pressure and according to shop manual it was in spec. 6-8 psi. My question is their a orifice that would be between fuel filter and seat assem. that I am missing?
Old Feb 21, 2017 | 03:15 PM
theothewolf's Avatar
theothewolf
Stupid question but how is the float looking?
Old Feb 21, 2017 | 03:38 PM
LARIAT 85's Avatar
LARIAT 85
Check the needle and seat. If the needle is stuck or if there is debris in there, the needle won't come down and the float will stick.
Sticky float = flooding carburetor.
Old Feb 21, 2017 | 03:50 PM
Tedster9's Avatar
Tedster9
That almost has to be the problem, assuming the fuel pump pressure isn't excessive. It's good practice to replace needle and seat, if they aren't part of a rebuild kit. Float height/fuel height check carefully.
Old Feb 22, 2017 | 01:37 PM
mkhmann's Avatar
mkhmann
Thanks for info. Needle and seat new. Ended up installing small gate valve between fuel pump and carb so I can regulate pressure
. Runs great.
Futzy
Nov 3, 2014 05:01 PM
clinkfield
Dec 11, 2013 01:15 PM
Steves55
Aug 12, 2010 12:59 PM
Blutox
Mar 1, 2008 12:51 PM
ackusackus
Jun 21, 2004 01:42 AM
