EGT Guage
Old Jan 31, 2010 | 11:55 PM
  #31
chicagodragon's Avatar
chicagodragon
thats a good way to start. if nothing happens, go with it. hopefully somebody knows for sure and will chime in
Old Feb 7, 2010 | 10:59 PM
  #32
newportman's Avatar
newportman
I'm gonna order mine tomorrow, where did you drill the hole for the egt sensor ?
Old Feb 7, 2010 | 11:01 PM
  #33
newportman's Avatar
newportman
I'm gonna order mine tomorrow, where did you drill the hole for the egt sensor ? How does the dash part come off ?
Old Feb 7, 2010 | 11:03 PM
  #34
chicagodragon
driverside exhaust manifold. as close to the last cylnder as possiable
Old Feb 7, 2010 | 11:07 PM
  #35
chicagodragon
take off the bottom part first. (2 )7mm screws, and it snaps out. the black paart where you will be mounting it has 2 hidden screws. one behind each of the peices of trim. i dont have a pic. after the screws are out, it snaps out too.
Old Feb 7, 2010 | 11:09 PM
  #36
chicagodragon
look at the pic on page one. the trim between the gauge and ac vent pops out, and there is a screw behind it. same on other side
Old Feb 8, 2010 | 01:25 AM
  #37
newportman's Avatar
newportman
Thanks, It really looks good in your trk.
Old Feb 8, 2010 | 03:15 AM
  #38
richdawg's Avatar
richdawg
This is where I drilled and tapped with 1/8th inch NPT
Probe was ordered from Auber.
Old Feb 8, 2010 | 08:18 AM
  #39
97250hd-earl's Avatar
97250hd-earl
do you need a brace to hold it up, or does it just snap in though the hole, what keeps it from cracking the plastic from vibration and what holds it in place.
Old Feb 8, 2010 | 08:48 AM
  #40
Andy's250's Avatar
Andy's250
it looks like there are little clips that hold it from the back when it snaps in
Old Feb 8, 2010 | 09:34 AM
  #41
richdawg's Avatar
richdawg
The gauge is very light in weight (all plastic) the clips will hold it securely if the mounting hole is not oversize. The clip are part of the gauge.
Old Feb 8, 2010 | 10:55 AM
  #42
97250hd-earl
thank you, I have been looking at them for a while, can you boost and egr to work on the gadge by selecting back and forth to change the reading.
Old Feb 8, 2010 | 10:59 AM
  #43
chicagodragon
no, only one per gauge
schoo
18
Mar 3, 2017 02:21 AM
philv
Jan 1, 2017 10:31 AM
FOUNTAIN 1
Dec 7, 2016 10:36 PM
ligito
Nov 13, 2016 07:35 PM
dmag67
Feb 26, 2016 07:29 PM
