hey if i have an autometer pyro already installed can i use the probe and wiring from it and re route it to go to the back of that gauge? or does it take a different probe and wiring setup
ok i see the ones on ebay, i was thinking abt getting a water temp sensor from them to, Anyone have an idea how that connects, do you just replace your old sensor with a diff one or have to tap into the housing somewhere?
ask around and see you can put in a "t" , that would give you both sensors, dash and meter. the meter will only read one. to do pyro and water , you would have to get 2 meters.
WOW!!!_____Glad to finally see some interest in these gauges, I still only have the pyro gauge. I am currently snowbirding it Parker AZ. the gauge has preformed well for me so far, probably about 3500 miles approx. 1700 towing a 14,000lb 5th wheel trailer. Definitely have got to have a pyro for this kind of towing, I have gone over 1250 degrees a few times on our trip but usually notice right away. I will do the audio alarm as soon as can get to it, hopefully for our return trip.
yes i was planning on running the 2 gauges, I like were you placed them in the dash but is there room for 2 of them in that spot, Im not sure what you mean about the t fitting, I just wanted to get an idea how you hook up the water temp sensor, since i got no idea how it would work with that gauge,
if you want to use this meter for water, you would have to remove the factory temp sensor, and install the one that comes with the meter. what i meant by t was so you could use the factory and aftermarket gauges.
mines a 95 so i dont think it throws codes as much like 96 and newer obd2 ones, i can just pull the wire off and see what it does, i doubt the check engine light would come on.
