Hey everyone I need to either rebuild or replace my toasted 9" and was curious if anyone knows the width of the 9" in a 1961 F100 or any 60's F100. Also want to know if anyone here knows if a bronco 9" is the same width as a F100 or what vehicle came with the same width rear end. Thanks in advance!
The 1966/77 Bronco's 9" axle housing is much shorter than any year F100. 1978/86, it's longer than 1957/72 F100's.
The 1961/72 F100 axle housing is the same length, but why replace the whole tamale?
All you need is the third member aka pumpkin.
Any 9" third member from a 1957/73 car, 1957/73 F100, 1969/73 E100 (Econoline), 1966/73 Bronco will work.
NOTE:
Some 1962/79 cars use an EIGHT INCH rear end...it looks very similar to a 9 inch.
