tranny problems
Old Oct 15, 2009 | 07:33 PM
sharifpnt's Avatar
sharifpnt
tranny problems
I have a 1989 ford ranger 4x4 with a A4LD tranny , the problem is when i put it in gear it shifts very hard and the motor wants to die. Any suggestions
Old Oct 15, 2009 | 11:56 PM
KhanTyranitar's Avatar
KhanTyranitar
Your torque converter lockup is stuck on due to an internal fault in the trans. It can be electrical or a leak in the valve body, or the solenoid is stuck open. Your trans probably needs an overhaul, those solenoids most often fail from extreme overheating.
