Removing the transmission???
Old Oct 15, 2009 | 08:29 AM
Ford79's Avatar
Ford79
I'll be doing this soon and want to know if I need to support the engine after removing the trans. Will it sit fairly level or will it tip back and allow the turbo to contact the firewall?
Old Oct 15, 2009 | 11:47 AM
Layson's Avatar
Layson
It will sit in there fine. You might want to just glance at the up-pipes and make sure they are not hitting anything. I don't think they will unless you lower the tranny down while attached to the motor and then it will pinch the up-pipes/turbo.
Old Oct 15, 2009 | 12:19 PM
stroken's Avatar
stroken
mine has been out several of times. it wont sit level but will sit fine, no need to support, while trans is out check uppipes for leaks.
A little peice of advice, DO NOT pull trans and transfer case together, that makes for a heavy SOB, i would pull it one at a time.
Old Oct 15, 2009 | 12:46 PM
Layson's Avatar
Layson
Mine balanced perfectly on the jack with the transfer case attached. Then I just swapped Tcase's out of the truck. Worked out real good.
Old Oct 15, 2009 | 01:00 PM
Ford79's Avatar
Ford79
Thanks Kenny. Up pipes WILL be replaces with the trans out, already have the bellowed pipes sitting on the shelf. T case will be removed first also, no need to wrestle with more weight than needed.
Thanks for the advise.
Old Oct 15, 2009 | 01:05 PM
stroken's Avatar
stroken
you must have a special jack, ive tried it 3 or 4 times and it always tries to tilt back off the trans jack.
Old Oct 15, 2009 | 01:36 PM
Layson's Avatar
Layson
Nope... LOL. I just had an adapter plate for my floor jack. It worked fantastic, didn't even need to strap it down. I wouldn't of believed it either if I hadn't done it. LOL
but every truck is different.
to the op: You might want to pull the transfer case before, then stick it on after the tranny is out and see how it balances. If you don't like it just pull out the 6 bolts and stick it in after the tranny... I just hate to wrestle that Tcase. It can be a pain, I have had mine out a few times and my buddies a few times as well. It gets tiring holding that thing up there and getting the splines to line up.
Old Oct 15, 2009 | 03:44 PM
stroken's Avatar
stroken
I want to get an adapter plate for the trans jack, a little arm thingy that holds the tcase. I had to strap mine down!
Old Oct 15, 2009 | 04:02 PM
Kwikkordead's Avatar
Kwikkordead
I took mine out with the TC attached, MUCH easier for me to get it done that way.
Old Oct 15, 2009 | 05:00 PM
Layson's Avatar
Layson
I tried to get my buddy to pull the transfer case with the tranny too on his Zf6. But wouldn't do it. It is nice to see the pics though!!
danlee
Dec 16, 2009 10:09 PM
Copedawg
Sep 19, 2009 05:03 PM
boxcar1974
Jun 9, 2008 08:36 PM
slmd350
Jul 5, 2006 03:16 PM
