Help Removing Yoke
Old Sep 19, 2009 | 11:33 AM
Copedawg's Avatar
Copedawg
Help Removing Yoke
I have removed the drive shaft and the nut on yoke - but unable to remove the yoke off the differnetial. What is the trick on removing the yoke??
Thanks
Old Sep 19, 2009 | 12:34 PM
pjwoolw's Avatar
pjwoolw
Thats what the documentation says to use. I've never had to do this on a Ford.
Old Sep 19, 2009 | 12:43 PM
Copedawg's Avatar
Copedawg
Thanks for the quick response! I am on the laptop on the tailgate waiting for some input. I have a gear puller I may try to use. You normaly just knock it off with a hammer?
Thanks
Old Sep 19, 2009 | 01:16 PM
Copedawg's Avatar
Copedawg
i feel like iam doing something wrong. I pulled the shaft and removed the nut. Thats all I have to do right? Then the yoke should come off, right?
Old Sep 19, 2009 | 01:48 PM
JTyler11688's Avatar
JTyler11688
Yes, you only have to get the driveshaft and the retaining nut off, but keep in mind that they're put on with something around 400 lbs/ft of torque. I used a gear puller on mine... use the biggest one you got or you can find, they're not easy.
Old Sep 19, 2009 | 05:03 PM
Copedawg's Avatar
Copedawg
Thanks Tyler! It was not a PITA at all, it was a PITFA! I got it though.
Powerstoke73
17
Aug 1, 2014 01:44 PM
low54
May 15, 2009 08:40 PM
eprn1n2
Apr 6, 2009 06:00 PM
DeanG
Jul 24, 2008 06:47 AM
MikeFlorida
Mar 20, 2007 07:29 PM
