1977 351m highboy headers?
Old Nov 9, 2009 | 08:09 PM
FordMuddin''s Avatar
FordMuddin'
ohh alright, thanks, says it won't fit a dana 60 though. . . looks like i'm outa options, haha.
Old Nov 9, 2009 | 08:16 PM
jecsd1's Avatar
jecsd1
Hedman Headers, 351M 400 they have these ones that are fenderwell exit that will clear any axle. IF you're into fender exit headers. good luck. I'm out of ideas after this
FordMuddin'
thank you very much, apreciate it.
Old Nov 9, 2009 | 08:46 PM
Blown 331's Avatar
Blown 331
I can't see any reason why a highboy would take different headers than any other 73-79 4x4, can someone tell me the difference in the headers?
Old Nov 9, 2009 | 09:33 PM
rfe1979's Avatar
rfe1979
Highboys are differant in a number of ways. The differance that is making it hard for us to find headers is that the frame cross members are in a differant location. Power steering, transmission, transfercase, axles, brakes, are all differant. Then you have the early 77's that had changes making it even harder to find parts. Basicaly Highboy's are completely differant truck. Unless you have had one you wouldn't have ever known how much they differ. Some people who have had them and still didn't know.
Old Nov 10, 2009 | 04:23 PM
FordMuddin'
i believe that the highboys also have a skinnier chassis, correct me if i'm wrong.
Old Nov 10, 2009 | 09:48 PM
lostinfords's Avatar
lostinfords
I have a set on my 77 4x4 f250 crew cab w/ the 351M 4spd and a d60/LP and they fit, installed by prior owner, there is a tag on them , I will try to get some pics and seee what the tag reads ...who makes them and get back to you guys...as far as frame widths, fronts are the same width... the rear section is about 3" narrower, thus causing the problem w/ the fit of the aft gas tanks, also use 2-1/4" wide rear springs instead of the 3" wide.
Old Nov 11, 2009 | 08:19 AM
Blown 331's Avatar
Blown 331
Ah. I guess I wasn't realizing that the 1977 Highboy was only a half year truck. The 77.5 is a lowboy and the 76 would have an FE.
I had a 1975 full time highboy with a 360 what I sold to my uncle. I am planning on buying it back to use as a beater truck once my half ton is back from paint.
Somewhat off subject but which highboys had a Dana 60 in front?
Old Jun 22, 2019 | 03:26 PM
Andyrooney's Avatar
Andyrooney
Did you end up selling?
Originally Posted by redsuperduty
I posted on the old thread that fordmuddin brought back..... I've got a perfectly original (except for headers) 77 highboy that I bought recently. The previous owner had just put them on, I want this truck all stock. I will trade these headers even up for the correct manifolds.
Did you end up selling these? Ten years later and I'm looking for a set. Or do you know where I can find them?
Old Jun 22, 2019 | 03:27 PM
Andyrooney's Avatar
Andyrooney
What did you go with?
Did you ever find headers for this truck? I now kwn a 77 highboy and an having a hell of a time finding headers to fit
Old Jun 22, 2019 | 03:32 PM
Andyrooney's Avatar
Andyrooney
Did you find out what headers were on your truck?
Old Jun 22, 2019 | 08:10 PM
lostinfords
Still have them
Old Feb 18, 2021 | 01:22 PM
  #28
dan7703's Avatar
dan7703
did you ever find a set that worked?
Dave2488
Jul 17, 2012 04:04 PM
picuplines
Feb 23, 2010 07:22 PM
likethefords
Jul 23, 2008 10:06 AM
riverdog
Mar 30, 2007 01:30 PM
