Sponsored by: Auxito
Air Bag Indicator Light.
Old Oct 14, 2009 | 10:00 PM
brc777's Avatar
brc777
I purchased a 2002 F150 a couple of weeks ago and the air bag light flashes and then stays on. I ran into the guy I bought it from today and he said he was told it was the air bag on/off switch gone bad.
Well that is not my problem. This is.
My Dad has a 2001 Mazda B3000 (Ford Ranger). So I took the switch out of his truck to see if that would solve the problem on the F150. It did not and now after installing the switch (twice) back into the Mazda which was working perfectly fine it started flashing and won't go off.
It flashes 2 times then seven
Now I have my Dad mad at me.
So, any help would be appreciated.
Thanks,
brc
Old Oct 14, 2009 | 10:15 PM
redwood's Avatar
redwood
When you turn the air bag on and off, does the light come on right above where you put the key in? You're getting a code 27, which would indicate a burned out bulb, and it will affect the operation of your air bag system.
brc777
1983 - 2012 Ranger & B-Series
19
Apr 2, 2015 12:39 PM
brc777
Apr 3, 2012 04:06 AM
brc777
1997 - 2003 F150
Oct 16, 2009 04:41 PM
brc777
1997 - 2003 F150
Oct 15, 2009 09:46 PM
brc777
Oct 14, 2009 11:22 PM
