Door Hinge Pin Removal
Old Oct 14, 2009 | 05:48 PM
flatheadjohn's Avatar
flatheadjohn
What are some of the methods some of you have used in removing stubborn door hinge pins? A PO of this 52 F-1 I have used a 5/16 bolt with the head cut off on the top hinge and the bottom one appears to have been in there since day one. I've sprayed WD-40 on them and tried to hammer them out using a drift pin the same diameter as the pins themselves but to no avail. They didn't even seem to budge! Last but least I guess I can cut the hinges on the door since the door is junk anyway and I've got another one to replace it. Any thoughts, ideas would be helpful.
Old Oct 14, 2009 | 07:45 PM
Old F1's Avatar
Old F1
Why can’t you just unbolt the complete hinge, you might have to because of what I am going to tell you. And don’t ask me how I know this! (man, am I dumb). As you can see from the picture the pin is serrated and has an slightly larger diameter at the top, so even with the head cut off it has to be driven up from the bottom ...........or taken off and put in a vise upside down. I used an excessive amount of oxy/acet heat and bent two pin punches to get mine out,………….the wrong way! I was wining to one of my buds at coffee that night and he said, it’s easy if you use an air hammer, which I have and never thought of!
Old Oct 15, 2009 | 01:53 AM
Julies Cool F1's Avatar
Julies Cool F1
I had to drill mine out. The replacement pins come in oversized variations if you have wear or slop. Be sure to get the stainless steel ones.
Old Oct 15, 2009 | 06:33 AM
reg1952's Avatar
reg1952
I drilled the top head off and down inside the pin about and 1'' with a 1/4 '' bit.A little heat then beat it up from the bottom.
Old Oct 15, 2009 | 05:34 PM
john smith jr's Avatar
john smith jr
I did the same thing as reg1952. It was no piece of cake
Old Oct 15, 2009 | 06:37 PM
ranger1995's Avatar
ranger1995
who sells the hinges, just in case they refuse to come and you have to cut the hinge to get the door off?
Old Oct 15, 2009 | 10:19 PM
Julies Cool F1
NO ONE - Be careful!
Old Oct 16, 2009 | 11:24 AM
ranger1995's Avatar
ranger1995
not good, some one already cut the lower hinges!!
anybody got a set they to let go of? pretty please?
Old Oct 16, 2009 | 12:12 PM
Julies Cool F1
Well this question has been asked a few times - buying new hinges. And the answer usually is the same. You get the new hinges with the new door you are going to buy. Maybe some of the guys have some out there they can get off. Good Luck!.
Old Feb 3, 2010 | 01:14 PM
Doraville's Avatar
Doraville
Drivers side came out without too much trouble, but we can't get the passenger side out with any kind of hammer. Looks like we'll be drilling it out.
-DV
Old Feb 3, 2010 | 08:27 PM
ct50f1's Avatar
ct50f1
Originally Posted by Doraville
Drivers side came out without too much trouble, but we can't get the passenger side out with any kind of hammer. Looks like we'll be drilling it out.-DV
Good luck drilling. I tried it but the pins on my '50 F-1 are hardened steel. Looks to me like the only thing that's going to work is a lot of heat and a big hammer.
Gwilkrrs
22
Dec 11, 2023 02:38 PM
Outlaw56
Aug 31, 2014 01:47 PM
drptop70ss
Mar 26, 2014 03:50 PM
aussiecowboy
Sep 17, 2012 05:01 PM
48fordcoe
15
May 21, 2012 05:33 PM
