Engine temp runs cold
Old Oct 16, 2009 | 03:37 PM
Hussler's Avatar
Hussler
Originally Posted by mustang68s
I just ordered the 203 thermostat, so hopefully that will solve my issues. I did not buy a new water neck yet. I'll take my chances at first. I can get one later if I screw this one up.
When I did my 203 I got a new water neck, locally, and it leaked like heck so I just cleaned up the old one and used it. One year later and all is still good.
Old Oct 16, 2009 | 04:01 PM
mustang68s's Avatar
mustang68s
That makes me feel a little better.
Old Oct 16, 2009 | 06:39 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
...With the new t-stat and waterpump (I broke one of the filler neck bolt in the pump)...
I also did this, but was determined not to buy a new pump. So I took the water pump off the motor and mounted it in a vise. I drilled out the broken bolt, pretty easily too, I was surprised. I then stuck a bolt up through the hole such that the hex would be on the bottom side of the pump when installed, and the 'stud' was now sticking up. I used 5 min JB weld in the hole before installing the bolt, and around the bolt head.
So now I have a perm stud sticking up and just need to run a nut down the stud to tighten the neck down.
Took about 30 min. to do the whole thing.
Thought I'd share for anyone else with the same problem, instead of having to buy a new pump.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Oct 16, 2009 | 07:28 PM
lud04X's Avatar
lud04X
I had the same thing happen to me. The truck would never reach normal operating temps, even in the summer while towing. I replaced the thermostat with one from Autozone and its been fine for a few months now.
pi653
19
Jul 13, 2017 08:13 AM
f150country
Dec 1, 2016 10:53 PM
4.2SVT
Feb 4, 2016 03:31 PM
Bigtruc
20
Dec 26, 2013 10:24 AM
MattP51
22
Apr 9, 2009 07:49 AM
