hesitation and stalling
Old Oct 14, 2009 | 01:27 PM
fordmudgrappler's Avatar
fordmudgrappler
i have an 89 f250 with a 351w, and it hesitates constantly and when i put it in gear and put my foot on the gas the volts drop wayyy down and sometimes (most of the time) stalls. but if it warms up it will slightly hesitate. when i turn on the fan or turn my blinker on or anything really the voltmeter will drop a little. could i have a bad alternator or alternator regulator? or just a crappy battery? and would this also cause it to hesitate or stall?
Old Oct 14, 2009 | 01:45 PM
jimjoebob99's Avatar
jimjoebob99
I would check all your battery connections really good. Don't forget all your grounds to the body, frame, and engine. It might not be getting a good power or ground and this could cause your voltage meter problem. Does it drain and not charge back up over time? That will tell you if your alternator is working. As for it getting better when it warms up, i'm lost on that one. Maybe someone else can chime in and give you a hand with that.
Old Oct 15, 2009 | 03:09 PM
fordmudgrappler
i checked all the connections, they seem to be fine. do you or anyone else have any suggestions?
Old Oct 15, 2009 | 10:24 PM
f1drivr's Avatar
f1drivr
My 93 F-150 was doing something like that. It was the plugs.
Old Oct 16, 2009 | 06:26 AM
jimjoebob99
I would pull your codes. You can go to Ford Fuel Injection and find out how there. Post them back here and we can see what else we can do for you. Also I would suggest a good tune-up. Plugs, cap, rotor, air filter, breather, pcv, fuel filter, and your plug wires if they are old. That will give you a good idea if it's just a general use part and eliminate the obvious. If you get a chance check your fuel pressure also. The hesitation should be an easy one to track down.
As for the alternator and battery gauge, I would say that if it's charging and you don't have to jump it with another car or a battery charger it's probably fine. Mine has quite a swing when I turn certain things on and off in my truck. Good luck and let us know!
TurtleTruckSC
Oct 25, 2014 07:49 AM
Rusty_S
13
May 20, 2014 11:00 AM
chi6488
6.4L Power Stroke Diesel
38
Jun 15, 2007 11:36 PM
ccollins
Nov 22, 2006 06:56 PM
cjcocn
1997 - 2003 F150
Jun 14, 2005 01:07 PM
