engine temp incorrect
Old Oct 12, 2009 | 12:39 PM
JDH70518's Avatar
JDH70518
I have a 2006 F350 that had an issue this morning. When I got in the truck and turned the key on the panel said check engine temperature. The gauge was pegged in the red and my outlook monitor said 300°. This cannot be possible for the truck had been sitting in 70° weather for over 12 hours. I started it and ran it for about 5 minutes, running very weak with fan clutch engaged the entire time. After 5 minutes the temperature immediately came down to the normal 200° and ran fine all the way to work (30miles). It did the same thing when I got in it at lunch. The truck is not running hot but somehow the computer says it is. Does anyone have any suggestions. I would rather not start changing sensors, part, etc. without hearing some suggestions.
Old Oct 12, 2009 | 12:45 PM
JDH70518's Avatar
JDH70518
Also ran the heater when first started to see if motor was actually hot. The air was cold for a while just like normal.
Old Oct 12, 2009 | 12:50 PM
cartmanea's Avatar
cartmanea
Bad temp sensor or bad wire somewhere.
Old Oct 12, 2009 | 01:18 PM
JDH70518's Avatar
JDH70518
Do you happen to know where this sensor is located on the engine.
Old Oct 12, 2009 | 01:57 PM
cartmanea's Avatar
cartmanea
No I don't.
gary.aderhold
50
Dec 11, 2015 05:48 PM
mercuryguy
Aug 27, 2012 07:11 PM
Drew Owsinski
1978 - 1996 Big Bronco
Aug 8, 2012 05:26 PM
oldblu65
Jun 30, 2012 04:19 PM
ocean_461
Jul 28, 2003 09:47 AM
