Stuck block drain plug
Old Sep 10, 2011 | 06:27 PM
Piolet's Avatar
Piolet
Anyone got a tip or trick to remove the block drain plugs?
Mine are rusted solid into the block and no amount of effort on my part could budge them. Tried PB Blaster and soaking them.
I can't think of a way to improve leverage in the tight space, so short of removing the engine or drilling them out is there anything else to be tried?
Thanks.
Old Sep 10, 2011 | 06:40 PM
BLADE35's Avatar
BLADE35
That first time can suck throw on a few extensions and get it out to where you can get a good go at it
Old Sep 10, 2011 | 06:46 PM
sandmanf250's Avatar
sandmanf250
stuck plugs
if you can do it drain the block,heat the block a bit,and use an impact wrench.heat and vibration are your friends.
Old Sep 10, 2011 | 06:55 PM
69cj's Avatar
69cj
I used an 18" pipe ext. on my allen wrench. It didn't stand a chance.
Piolet's Avatar
Piolet
I'll try a hex-bit socket on an impact and see how it goes.
Don't have one in the tool box so it won't be tomorrow, but trying it after the block is warm is a good idea too. Thanks.
Old Sep 10, 2011 | 07:02 PM
Piolet's Avatar
Piolet
I thought of that but the pipe I have handy is too big. Maybe I'll grab something smaller from the home store, would be good to have. Was that a regular length allen wrench or a long type? I think I'd need to get it out past the manifold.
This one it feels like I'm rounding it out.
Tonight I think I need ibuprofen for the amount of yarding I did on that thing ... didn't even tickle it.
Old Sep 10, 2011 | 07:13 PM
69cj's Avatar
69cj
1 1/2" by 6" allen
Old Sep 10, 2011 | 07:17 PM
BLADE35's Avatar
BLADE35
might want to get the Hex socket set seems like iv ra into these type a couple other things iv done to the truck
then 3-4 extensions and a good old breaker bar or a peice of PVC pipe on the end of the ratchat
I got sick of getting burned when doing the coolant flushes
Old Sep 10, 2011 | 07:33 PM
Piolet's Avatar
Piolet
I've got the fumoto valves ready to go in.
dustmote
22
Aug 6, 2015 09:00 AM
ealbertson
Apr 2, 2006 07:30 PM
Ed
Aerostar
Jun 13, 2005 08:35 PM
cub 1947
Aerostar
Jun 24, 2004 02:41 AM
92Custom
Mar 8, 2002 06:11 PM
