intake question
Old Oct 11, 2009 | 12:50 PM
6.0 f250's Avatar
6.0 f250
intake question
So i am doing a egr delete kit from elite diesel. i have everything out pretty much but everything that i have about doing this tells me that you dont have the turbo out to do this including the instructions from elite. is there some sort of trick that i am missing to get the intake out it doesnt seem like it is possible to get it out anyone else ever have this problem? does anyone know what i am talking about? everything is all loose and it just seem to catch on the turbo
Old Oct 11, 2009 | 01:29 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
I don't see how it's possible to do an EGR delete without removing the turbo
Old Oct 11, 2009 | 01:39 PM
dcaddi2's Avatar
dcaddi2
Your intake has a loop on the rear end, and that won't let you remove it from under the turbo.
For reasons like this, I've had that loop cut out and welded shut on the ends, so mine would come out.....
Old Oct 11, 2009 | 01:51 PM
6.0 f250's Avatar
6.0 f250
that is what it is caught on i thought the same thing but everything that i have says that it is possible to do it without and i cant get my bolts out of my turbo so now i am just screwed cant get it back together and cant get it apart anymore thanks for the input
Old Oct 11, 2009 | 04:02 PM
dcaddi2's Avatar
dcaddi2
the bolts in the turbo take a 10mm socket or wrench. I usually use a 12 point "ring spanner" - it'll give you a little more flexibility in that small room - and to get the bolt start, I hit it with my palm. Usually the bolts - like these - exposed to extreme heat has the ability to appear as they seized, but a good "kick" usually starts them.
Some PB Blaster overnight would do magic also.
brkncly
6.4L Power Stroke Diesel
Jul 25, 2013 07:26 PM
JJ1101
Mar 20, 2011 10:22 PM
BishopRyan
15
May 15, 2008 08:21 AM
FFemt5287
Dec 28, 2007 01:39 PM
dpoelstra
Exhaust Systems
Nov 25, 2002 04:25 PM
