Crank case venting
Old Oct 11, 2009 | 07:52 AM
CaptainIPSC's Avatar
CaptainIPSC
Crank case venting
I'm getting close to the end of putting a 460 in my pickup. My problem is the valve covers were stripped when I got the donor engine. So how do I build/construct my crank case ventilation system. PCV valve in one valve cover and a vent in the other?
Old Oct 11, 2009 | 10:47 AM
75F350's Avatar
75F350
Stripped valve covers????? What is that?
Just put some valve covers on it. Many to chose from.
Old Oct 11, 2009 | 10:54 AM
Bear 45/70's Avatar
Bear 45/70
Yes, vent in one cover and PCV valve in the other. Most factory setups have the valve in the right valve cover and the vent on the left. This is because of the direction of the cranks rotation helps to move the air thru the engine in that direction.
Old Oct 11, 2009 | 12:12 PM
CaptainIPSC
By stripped I meant the valve covers didn't have grommets or anything to guess/copy from. The 400 I yanked out had a pcv in the rear of the passenger cover and fill cap (breather) in the front of the drivers valve cover. I was going to copy it but thought I'd ask here to make sure all's good.
the
Apr 23, 2012 11:23 PM
CaptainIPSC
13
Mar 9, 2010 08:12 AM
pmbmax
Feb 9, 2007 09:43 PM
Ol' Blue
18
May 26, 2001 05:39 AM
