broken bolt in water pump
Old Nov 4, 2009 | 10:14 AM
lew52's Avatar
lew52
Originally Posted by pintoches
I broke off 5 water pump bolts and cracked the timing cover on my 351. is propane hot enough or do i need some thing hotter. I got mad and walked away i will work on it more this weekend.
...Yeah thats not good , but look at the bright side , i think five is a world record !! Sence you need a new timing cover don't worry about the bolts that broke in the cover , you just need to get the bolts out that screw into the block . Take a good look at the timing chain , its a good time to replace it if theres any slop.... Lew
Old Nov 4, 2009 | 10:18 AM
pintoches's Avatar
pintoches
the ones in the cover came out great its the bolts in the block that are broke. since i set the record does that mean someone will come fix it for me>
Old Nov 4, 2009 | 10:36 AM
Old93junk's Avatar
Old93junk
Yes, the E-Z out and Heli-coil factory reps have been dispatched to your house, please stand by and watch for them!........................Did the bolts break off down in the block, or can you now remove the timing cover and see enough of the bolts left to get a hold of with a vise-grip?
hail destroyer
Oct 3, 2016 06:07 PM
NotSoSporty98
Aug 14, 2016 12:53 PM
djed
Mar 23, 2016 06:17 PM
flapbreaker
Aug 1, 2014 08:24 AM
Epd444
24
May 22, 2012 11:32 AM
