shop manuals
Old Oct 22, 2009 | 04:16 PM
jfroldan's Avatar
jfroldan
shop manuals
Is there a big difference between the shop manuals for the trucks between 87 and 90? Is a year or two a big deal around that period?
thanks
JF
87 F-350 Crew w460
Old Oct 22, 2009 | 04:27 PM
BucksTrucks's Avatar
BucksTrucks
Should be the same. But the 87 460 may have been carbed and the 90 will be EFI
Old Oct 22, 2009 | 05:12 PM
subford's Avatar
subford
thanks
JF
87 F-350 Crew w460
The 86-88 were close with some changes each year.
The fuel system went to Fuel Injected in 1988.
In 1989 electrical harness changed in the engine compartment and now there was a big round plug at the firewall.
The fuel system changed again in 1990 with with the high pressure fuel pump now in the tank and no longer did they used a fuel selector valve on the frame.
There was a big change to just about everything in 1992.
Old Oct 22, 2009 | 06:16 PM
jfroldan's Avatar
jfroldan
that would mean that I should look for a shop manual from 86 or 87 for my 460 carb and it would not be covered in the 88 manuals. Would it be the only main thing? carb vs EFI?
thanks, I am new to this truck and wanted to get the manuals to get to know it better.
JF
87 F-350 Crew 460
Old Oct 22, 2009 | 08:59 PM
subford's Avatar
subford
JF
87 F-350 Crew 460
I do not see anything at all about a 460 carb in the 88 shop manual.
Old Oct 22, 2009 | 10:46 PM
jfroldan's Avatar
jfroldan
How easy/hard is it to find a set of shop manuals for the 87 F-series? How much is a good price for the set nowadays?
thanks
JF
Old Oct 22, 2009 | 11:00 PM
gpedens's Avatar
gpedens
Old Oct 22, 2009 | 11:10 PM
jfroldan's Avatar
jfroldan
Yes, I saw that one, but was wondering if the price was too high. There is a set for the 88 MY going for $10 in the auction as of now. It probably won't go as high as $90...
If the price is good at $90, then I might go for it.
Old Oct 23, 2009 | 06:16 AM
subford's Avatar
subford
I do not see an 88 manual on ebay for $10.00. Also I do not see one at all on ebay for an 88 F-series truck.
You want the two volume set with the big second volume, it is the one that cost the most.
Do not get the one for the F & B, C, L or Medium Heavy Truck as those do not apply to your truck.
A lot of the two volume set for the F-series do go for around $90.00.
The link above is the only two volume set on ebay that I see for the 87.
Old Oct 23, 2009 | 08:22 AM
g_k50's Avatar
g_k50
Bishko part number 1101 available at Rockauto
Old Oct 23, 2009 | 08:33 AM
subford's Avatar
subford
Looks like a reprint or xerox copy of the ford manuals.
Old Oct 23, 2009 | 10:37 AM
1OldFordMan's Avatar
1OldFordMan
Not to be getting off topic or away from his problem, wondered where would you get a Motor's or Chilton"s new if you wanted one? Don't think The Zone carries them. Used to have a couple old ones for cars from back in the 80s / early 90s but can't remember where I got them. Didn't need them, so I just donated them to the tech school where Old Rusty still is. Hopefully by the end of the month or the first part of next month he'll be done. Would they even still have one for a '91 available or would I have to settle for a used one from E-Bay or Craig's List?
Old Oct 23, 2009 | 11:36 AM
subford's Avatar
subford
1OldFordMan,
I have a lot of Hearst Motors Manuals and the 1987-92 Light Truck & Van Repair Manual 9th Edition that I have does cover your truck.
I guess they are still around and you may be able to order an older Edition from Hearst Books.
Here is a link you may want to read:
Hearst Corporation
Old Oct 23, 2009 | 11:55 AM
1OldFordMan
1OldFordMan,
Hearst Corporation
Sub Ford, thanks for the info. Just want to say again, . Glad I found this.
Old Nov 4, 2009 | 10:45 AM
darthice's Avatar
darthice
try helm inc they are the publishers of the factory shop manuals i can get one for my 94 for around 105 plus shipping Service Manuals, Owner Manuals, Wiring Diagrams, Service Bulletins - Helm Incorporated
bigjob
Apr 19, 2022 05:06 PM
Drgslayr
1983 - 2012 Ranger & B-Series
Oct 19, 2013 12:58 PM
SC_Hoaty
1978 - 1996 Big Bronco
Dec 25, 2012 08:15 PM
l3roncoPOWER
Aug 9, 2006 12:29 PM
carpe_diem
Nov 10, 2003 09:39 AM
