Thermostat housing bolts
I'm in the middle of changing my water pump, and the three bolts that hold the thermostat housing to the water pump snapped off when I tried to take them out. Anyone know the thread size? It's the 3 bolts that connect the thermostat housing/neck to the water pump itself.
Thanks.
Thanks.
I have this saved in my PC
IH part number for the bolts: 1817817C1 and they were .21 cents each, $2.71 out the door including Tax...( for 12 bolts)
the updated Ford part number is W300005
The correct bolts are metric M6 X 1.0 X 20mm long, grade 10.9.
^^^^^ Always the option of the IH water pump with the integrated filter mount.
Re. the 'stat housing, somewhere knocking around online is a kit with a hard steel "flange" that sits behind the regular housing flange, and a set of longer bolts. Supposed to make for a better seal (housing flange doesn't bend), and I suspect the bolts would come out better next time.
That's where the master cylinder goes. If you look on your truck with automatic, you'll see an oval plate with 2 bolts, that comes off and master goes there.
I hate those water neck bolts. I had one break on me a couple years back and I got some threaded rod and nuts. Cut short pieces and threaded them into the water pump as studs, and used the nuts with lock washers to faten the neck down. Never have to worry about stripping those bolt heads or breaking them off in the pump ever again.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
