cel how to read codes?
Old Oct 10, 2009 | 01:30 PM
gopher2's Avatar
gopher2
hey guys got a 1996 f150 im want to do the check engine light flash the code thingy on fordfuelinjection.com but i cant find the port that the wire goes to the battery... is it hidden somewhere? i do have a port in the cab that says data link? can i use this?
Old Oct 10, 2009 | 01:38 PM
DBGrif91's Avatar
DBGrif91
Check on the driver side of the engine compartment- there should be two plug connectors that don't connect to anything. One of them is a single pin connector and that's the one you want to ground.
Old Oct 10, 2009 | 01:59 PM
White 97 xlt's Avatar
White 97 xlt
I think the 96 is OBDII, which means you need a code reader for the plug inside. I think what you are referring to is OBDI which is outside under the hood on older trucks..
pmoney1983
May 12, 2012 02:07 PM
isenegger
13
Jul 4, 2009 02:07 AM
tagunderson
Mar 9, 2008 09:24 AM
GPSMatt
Nov 4, 2005 08:01 AM
erikl85
27
Dec 2, 2002 04:19 PM
