I did the CCV mod and every once in awhile can get a smell of it. In fact I think the gal at the Sonic drive thru got a whiff of the fumes yesterday. You folks running a trap do you notice that the smell has diminished or is it about the same. Been thinking of using Ponyboy's design.
...My advice is to "hold your breath" or "stay upwind" and leave your CCV routed to the atmosphere with the shortest length of 3/4" diameter hose that gives a convenient run and exit point so the oil fumes don't coat the underside of the truck. In order to avoid "excessive" crankcase pressure or vacuum a CCV that's returned to the intake must have a well designed "regulator" meaning one that's matched to the "filter element" which traps most of the oil vapor so that it doesn't foul the intake system.
The two pictures below illustrate the considerations involved in such a design and even with their competent engineering staff Racor didn't get it done correctly in their initial effort because I had an early version of their 7.3L CCV kit and the regulator warning "pop up" button would stick and not alert the driver that the CCV filter was clogged and needed to me changed! There were several reports of dip sticks being blown out with those early versions...
If anyone's curious as to why my graphs and pictures keep disappearing after I post them it's because my "ripway hosting service" is for crap so I decided to break down and get my own web page and host my stuff there.
Originally Posted by nhill2090
cat's version here at the shop is a pretty nice setup. I have been thinking about calling the local dealer to see what one would cost.
IIRC, it has a replaceable filter element, an inlet, and outlet and an oil drain tube that could be vented or stuck back into the pan, etc.
That CCV unit is Cat's "ad hoc" approach for addressing the complaints of motorhome drivers who get a film of oil deposited on their "towed vehicle" which happens because the new C7 has its CCV vent on the side of the block and this causes the C7 to blow out more oil vapor compared to the older 3126 which had its CCV on the valve cover.
Cat says to change the CCV element in their unit every oil change to avoid excessive crankcase pressure but reports on motorhome threads indicate some units clog up well before then and over pressurize their C7 crankcase! I wouldn't even consider installing one of those Cat CCV units on my engine!
I'd like to see the "measured" curve for "pressure drop" versus "CCV flow rate" on a Cat CCV filter like the one in the first graph above on the Racor CCV filter but I don't think Cat has even made this basic measurement!
Actually, his won't clear up much of the smell. What Curtis & I are talking about is running a trap like that, but feeding it back into the engine instead of being vented like the link shows. I will work on mine this weekend, if I have enough time.
I am running mine back into the intake after my canister because I couldn't stand the smoke. It still lets a little oil back in, but I will just deal with it.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
I have the PVC pipe version of the CCV trap like Chris, but with a rounded cap on each end and a drain petcock on the bottom. I have plastic "pot scrubbies" inside for a filtering media and rerouted back to air intake. It does trap some oil, but it still allows some to pass through. The trap catches approximately 2 tablespoonsful every 2-3k miles. I have been pondering a way to make it more efficient, but haven't revised it yet.
Exactly!
I got rid of the stock CCV inlet that goes into the intake, but a friend of mine here in Denver has one sitting at home, so he's going to give it to me so I can use that to re-route back to the intake.
Any kind of trap should probably be run back into the intake to prevent any crankcase pressure. That and not to use a trap setup or filter elements that would cause any kind of restriction.
So Chris.... what's your design???????? Curious minds (like myself) want to know!
Yup that's it. I have two traps in my garage now. One is for Andrew and another is sitting - someone wanted one built for them but back out yesterday. Not that hard to do with all parts available at Home Depot. I get about a teaspoon or two every thousand miles or so. I need to change the pot scrubbers at next oil change this month. All I can say is no pressure issues and my CAC boots and intake is very clean.
Good to know, Chris. That's what I'm shooting for.
There's another member on PSN that lives here in Colorado, and his CCV trap is way different than any homemade setup I've ever seen. His is a canister that uses clips to hold the housing. 3 snaps and the entire canister comes off. Inside is a huge round foam filter, with a catch space at the bottom for any oil that drips down.
So far I have yet to find a canister similar to his setup. It looked nice, and I was going to try and copy the design if I can find something like that.
I think ponyboys design is perfect, and this is on my todo list. As far as filtration goes, was wondering about steel wool as an option. many different coarseness levels to try/play with as a more robust filtration media. i don't have the mod yet, so I am just thinking of "off the shelf" options, but seems like one with some variables to use at least.
my other off the wall thought was a way to heat the canister possibly, change the condinsation factor some, in fact, as i type this, maybe cool would be better, make the oil vapors thicker?
Its my friday night, and for once, I have nothing but thought time, hope yall don't mind the pondering.
Sounds like a cool idea. I'm not that imaginative. Actually, this canister idea is one similar to a guy on another board that I saw. Just tweaked it here and there to accommodate the parts found at a local hardware store instead of fabricating.
Tom
I used the copper pot scrubbers because the fear of having too think of media may cause restriction problems. I'm not an engineer by any means so my thought may be waaaaaay off. I did think about using a spin on oil filter as a vapor trap, we use that kind of setup on our bulk oil storage here at work. When we fill our tanks, they cannot vent to atmosphere without being ran through a filter of some sort.
Any experience with a filer/trap freezing? During hunting season I get out almost every day. I hunt 5 minutes from my house. So, my concern is that with the truck running for such short periods it may allow condensation to build and block the filter. I know this is not good for the truck overall but just want to make sure I'm not compounding the problem. So, at least that's my excuse for having the parts in the garage to do this for almost 2 years.
Gene had a few posts on a system to measure CC pressure. Anyone able to locate that thread?
