Went to pull my truck into the shop yesterday morning to do a transmission flush and power steering flush. Was about 20 degrees out, fired right up, but when i hit the go pedal, nothing, just sat there idling like i had never even touched the pedal. As it warmed up, the pedal started to slowly work better. Once warmed all the way up, it was fine.
I assume this is the little electronic sending box on the go pedal?
I seem to remember a similar problem before I changed my CPS? Been awhile since I did it and I have senior moments. Could have been before I changed the up-pipes also, was having problems with the EBPV.
If you turn on the key but don't start press on the pedal and you should hear a slight click and then the same when you let it off. Do this multiple times before and after cleaning.
