Searched and Read first--RAS question--please clarify
Old Oct 10, 2009 | 01:25 AM
Husky44's Avatar
Husky44
05 V10 4x4 Limited EX. Totally stock suspension, 84k miles
Tow a 26 ft enclosed snowmachine trailer with 4 mountain sleds. When I drop my trailer on, my rear end drops about 2-3 inches. I was thinking about doing add-a-leafs; didn't want to deal with airbags. Just read about the RAS. Will it solve my butt-dropping problem with my trailer on?
Old Oct 10, 2009 | 07:43 AM
gr8scott72's Avatar
gr8scott72
Maybe not solve, but will help tremendously. If it drops 2"-3", that's alot of tongue weight.
I would say give it a try. If you shop around, you can find the RAS for just over $200 and it only takes just over an hour to install. Best $200 and hour I've spent on my truck.
Old Oct 10, 2009 | 09:24 AM
LionFan's Avatar
LionFan
I agree, it helped my sagging rear end with the 28' Travel Trailer hooked up. It also reduces the bouncing when you go over bumps in the road.
Old Oct 10, 2009 | 10:42 AM
Husky44's Avatar
Husky44
That's an "eyeball" estimate. It's a visible drop, although handling's not affected tremendously. I don't seem to have the bouncing/swaying problem a lot of you experience. One of my biggest concerns is getting my nose down to the point that my headlights aren't blinding oncoming traffic.
I think I'll give it a shot.
Old Oct 10, 2009 | 11:07 AM
cbradford's Avatar
cbradford
I think the RAS and a good WD hitch with the correct set up and you should be fine. There are people here towing more of a trailer than you.
I know you eyeball a 2" to 3" drop, that does seem excessive, but do you know your tongue weight ?
Maybe Joe our local towing expert will chime in.
Old Oct 10, 2009 | 12:15 PM
scottman70's Avatar
scottman70
I know you said you didn't want to do the air bags, but I have them and they are great for exactly the issue you are having. RAS may firm it up and keep the sagging from happening, but the air bags will not allow the Excursion to sag at all with 1250 pounds of tongue weight. Look at my gallery pic, my hauler is fully loaded with my Polaris Ranger and gear for 6 people in it and 80 psi in the bags and doesn't sag at all! In fact it's about 1" higher than stock in the rear with the bags aired up! Fireston Ride Rites are around $200 or maybe a little more but money well spent if your sagging in the rear!!
Old Oct 10, 2009 | 12:43 PM
MarkMoore's Avatar
MarkMoore
I agree with cbradford - the RAS and WD Hitch is what you need.
Old Oct 10, 2009 | 08:26 PM
Matt M, PA's Avatar
Matt M, PA
I tow a 22' enclosed Haulmark trailer with my 05 V10 Ex. I always used my weight bars with the trailer when loaded. I suppose it was more habit than anything else. (I HAD to use them when towing with my former '94 Bronco)
I put the RAS in when the truck was almost new.
Anyhow...a couple weeks ago, I hooked up, and loaded the car without the weigh bars and to my surprise the drop was so minimal that I decided to go without them.
I saw no adverse issues when towing, and (unless it's my imagination) think it was better. Perhaps too little tongue weight is an equal issue to too much.
I will say that the RAS install added a slight rise in the rear to the Ex. During normal driving the ride was unchanged, handling improved. I think the RAS is worth every cent.
Old Oct 10, 2009 | 10:37 PM
Husky44's Avatar
Husky44
WD Hitch isn't really a good option. I don't have a way to hook onto the A frame of the tongue, since it's not exposed. At least not any WD hitch I've ever seen. The ones I know of you need to be able to wrap around the frame rails--I've got trailer on top of mine.
No, I don't know my tongue weight.
Scottman 70, I hear what you're saying about airbags, but I'd prefer not to have to do something that complex if I can get away with a bolt-on as simple as the RAS appears. To make airbags convenient, you need the on-board compressor and remote, and that drives the price up. The RAS appears to be an "install and forget" setup. Getting my crew loaded and headed out is enough of a challenge without having to mess with resetting suspension.
Plus, I'm not sure what the impact of subzero temps are on airbags, onboard compressors, air lines, etc, but there's got to be a potential for ice, clogging, etc. RAS just looks simpler.
I think that's what I'm going to try, anyway.
Old Oct 11, 2009 | 05:40 AM
cbradford's Avatar
cbradford
Sounds like a formula for disaster.
Old Oct 11, 2009 | 12:10 PM
Husky44's Avatar
Husky44
I'm curious why you say that?
Old Oct 11, 2009 | 07:53 PM
cbradford's Avatar
cbradford
1st you should know what your tongue weight to be sure your not overloading the hitch.
2nd you need to know the max weight of trailer to be sure your within MFGer (FORD) recommendation as far as if a WD is required.
Old Oct 11, 2009 | 10:59 PM
Husky44's Avatar
Husky44
Never said I didn't know trailer weight. I said I didn't know tongue weight.
I didn't expend a whole lot of energy trying to determine tongue weight (which it would take in AK, cuz there's not a public scale on every corner), in part because I knew trailer weight was fairly reasonable for this tow rig, and because after almost 4 years of towing with it, I have had ZERO handling issues, even when loaded with a car and a LOT of other stuff.
As I stated earlier, I know of no WD hitch design that will work on this type of trailer, as there's no way to install the brackets on the trailer frame.
I appreciate your concern, but I think your conclusion was a little excessive. I hardly think I'm courting disaster.
Old Oct 11, 2009 | 11:15 PM
western star's Avatar
western star
There is a thread entitled "Sale on RoadMaster Active Suspension" on pg 2 of this forum which might help you find a good deal.
Personally; I have RAS on my 73 F100 and my 01 Ex and highly recommend the system; I'd be amazed to hear anything bad about the system
Old Oct 12, 2009 | 12:08 AM
X-Hibition's Avatar
X-Hibition
It's a good thread too. I know the author is still waiting for his RAS to show.
He believes in it enough to order two, one for the X and the other for his Sub. What a guy, two big SUVs...
ddivinia
Aug 25, 2012 09:58 AM
luisp1966
Jan 21, 2012 01:40 PM
labman1014
Jul 28, 2011 04:14 PM
Scoob5555
Mar 18, 2011 10:44 PM
05ex604x4
Mar 21, 2008 08:19 AM
