hello,, some of you may have read my other posts about replacing my rear cover on my t-case(cracked at drain plug). Was listening to my truck and noticed it has a high pitch sqeak/sqweal niose coming from the rear output shaft area of the transfer case.
Would it be the bearing that's located there?
Also since i'm going to replace the rear half, should i replace or rebuild anything inside it(bearings, oil pump, ect.) I don't/can't spend very much $$ and don't want to have to tear it all apart and stuff if i don't have to.
Also anybody know of a good eploded view of the borg warner 1356 manual shift with a slip yoke?
