Block heater short
Old Oct 9, 2009 | 01:07 PM
itsjustdan26's Avatar
itsjustdan26
Block heater short
Hey guys,
So yesterday I was goin to test out my block heater on the 01' F250 CC SRW LB, and when I plugged it in I had a shock of my lifetime. It kinda hurt when you get zapped by the plug. So at a closer look its shorting out right behind the plug head. To the point that its melted the insulation and can see sparks. Is this a normal thing? If so..How would you fix this? I can go to Lows and pick up a plug head and attempt to re-wire it. Do you guys have a diagram of the ground, positive and whatever else maybe involved? Thanks as always!
Dan
Old Oct 9, 2009 | 01:36 PM
PwerStroke99's Avatar
PwerStroke99
just go to International and get a new cord, they arent too expensive, $20 or something. mine was shorting out last winter.
Old Oct 9, 2009 | 01:45 PM
Izzy351's Avatar
Izzy351
Yes, you can just put a new end on it. Green should be ground, black is "hot", white is neutral. However, it's just a resistor, so it really makes no difference on the hot & neutral. But on a polarized plug, neutral goes to the large blade, hot on the small. Ground is obvious.
Old Oct 9, 2009 | 03:31 PM
Ponyboychris's Avatar
Ponyboychris
Joe's got you covered. It's a common occurrence for these ends to rub inside the bumper bracket and cause the short. I had to re-wrap my plug end to keep it from rubbing through the insulation.
Old Oct 9, 2009 | 04:44 PM
87 F-150 I6's Avatar
87 F-150 I6
I would just pick up a new plug and rewire it. Sucks to get shocked!
chetspencer
Jun 23, 2013 12:19 PM
90pioneer
Apr 29, 2013 09:15 AM
FTrucker
Jan 2, 2012 01:04 PM
bcaughhorn
15
Feb 2, 2011 03:16 PM
5.4f250sd
Dec 11, 2010 12:58 AM
