Block Heater Short?
Old Dec 31, 2011 | 10:03 AM
FTrucker's Avatar
FTrucker
Block Heater Short?
Hey all, Good Morning,
It seems my plug in has a short, I plug it it in and I can hear little short sounds the 1st time I noticed it, I kept playing w/ it to be sure I wasnt hearing things. It kept hearing it here and there, and as I kept fooling w/ it, It began to crackle then smoke! Ha! Ok! No More plugging it in Now!
The wires dont seem exposed, but what do ya think? most likely the short is right there at the plug or close?
I seen the post from a ways back on a nice Morinco plug in Think when I get a chance I look for one of those. But I got bigger fish to fry as you'll all see another post for another topic. Thanks for any help.
john
Old Dec 31, 2011 | 10:08 AM
Vinford's Avatar
Vinford
Usually it right on the end in the plug part.
Ive changed mine twice because I didnt put a good enough one on the first time.
Old Dec 31, 2011 | 11:10 AM
Ponyboychris's Avatar
Ponyboychris
Most shorts happen at the plug end. I did the Marinco plug mod a couple of years ago and works fabulous. Here's my write up with pics and comments with each picture.
Marinco Plug mod
Old Dec 31, 2011 | 11:55 AM
FTrucker's Avatar
FTrucker
Thanks guys, I did look at your rwrite up, but now I'm fooling w/ the water pump.
john
Old Jan 2, 2012 | 11:16 AM
f350crewzer's Avatar
f350crewzer
Block Heater Short?
To follow up on this, I am having a similar problem with my 05 F-350 6.0, but I am about 99% sure its not the wiring. I have a Marinco setup, that I extended to my rear bumper. I mounted the plug bracket to the side of the rest of my hitch wiring. (this was more convenient then going through the grill or having it at the front of the truck).
Anywho, if I ohm out the wiring (at the plug) with it connected to the heater, it shows it's shorted. When I unplug it however, it's good. Is it possible for there to be a short in the heater itself??
Any help would be greatly appreciated. Figures this happens now that its cold out.....
Old Jan 2, 2012 | 12:43 PM
sgarder's Avatar
sgarder
If you test thru the wires with the heater hooked up there will resistance, however it should not be infinite or the same reading as touching the test leads together. I believe you can also test one lead to the wire and the other lead to chassis should not have any reading on meter, after all this is 110 AC going thru these wires
Old Jan 2, 2012 | 01:04 PM
f350crewzer
Yeah, each lead to chassis, I have nothing.
Across them I have about 15 Ohms.
ztruck
Dec 13, 2013 01:57 PM
meier63
Jan 22, 2012 12:50 PM
Liquid10Rider
Dec 27, 2011 07:31 AM
Dstosh
Jan 4, 2010 05:29 PM
ididntdoit99
1997 - 2003 F150
Mar 3, 2008 07:38 PM
