Need help asap
Old Oct 8, 2009 | 07:13 PM
mayer7196's Avatar
mayer7196
Need help asap
I am a newbie truck owner. I have a 2005 Ford F150 XLT 2WD. I like the idea of leveling my truck due to the nose dive and maybe getting 35's on one day. Anyway, I am getting my truck leveled next week and also getting wheels. I really like the American Eagle 1972's 17x9 wheels. The questions I have, and can't get them answered on other Ford forumns, is they are -11 offset, 4.5inch BSM. Can anyone explain to me in lamens terms on what exactly im looking at and if I will be ok going up to a 33" tire without rub (with the level kit)?? I understand my truck tires will be about 2" out of the wheel well. Please help!
mayer7196's Avatar
mayer7196
Eagle Alloy Wheels
here is the link to the wheels
Old Oct 8, 2009 | 07:42 PM
Greg B's Avatar
Greg B
Tire Rack's web site has all of the information on custom wheels. -11 offset means that the outside of the rim is off center outward by .433" or 11 mm. A rim with 0 offset would have the mounting flange ( the surface that bolts up to the rotor or drum) would be exactly in the center of the rim from inside to outside. 4.5 inch BSM is the distance from the backside of the rim to the mountinting flange. Offset and backspacing are closely related. As to whether your tire choice with your leveling kit and wheel choice will fit with no issues I can't answer for sure. The general consensus on this site is that a 33" tire will work without any problem. The diameter is only about 2" larger than the standard tire so it should work. Again Tire Rack can assist you with that information also.
Old Oct 8, 2009 | 07:55 PM
mayer7196's Avatar
mayer7196
Greg, thank you so much, going to check it out now, thanks again!
Old Oct 8, 2009 | 10:00 PM
Still Smoking's Avatar
Still Smoking
33's fit on my truck stock with no rub. Not sure on the offset and stuff but they were Mickey Thompson Classic II's 17x9. With a 2.5 leveling kit they say 35's will fit but depends on the offset there might be some rubbing and may have to do some trimming. Im clueless on offset and stuff. I guess I got lucky when I bought my rims cause at stock height I had no rubbing and some people do I have heard. Sorry Im not much help here.
chrison600
May 1, 2013 08:22 AM
hotwheel_2000
Ford Truck Parts for Sale
Sep 19, 2012 11:29 PM
DarrellJ
Apr 10, 2011 06:48 PM
HogTied
Aug 9, 2004 10:35 AM
