thread tape/pipe thread sealant on new glow plugs?
Old Oct 7, 2009 | 09:04 PM
shanes66charger's Avatar
shanes66charger
wondering what if anything i should put on the new glowplug threads??
Old Oct 7, 2009 | 09:37 PM
farmert's Avatar
farmert
I don't use anything, but a dab of antiseize on the threads wouldn't hurt anything.
Old Oct 7, 2009 | 09:43 PM
shanes66charger
thanks a ton! back to the shop i go
Old Oct 8, 2009 | 12:13 AM
Franklin2's Avatar
Franklin2
Try to avoid putting thread tape and sealers on glowplugs and other electrical sensors. The threads are the ground connection for the circuit, and thread tape and sealers can interfere with the connection.
Old Oct 8, 2009 | 09:56 AM
ghunt's Avatar
ghunt
I put some copper "high temp" antisieze on mine, I figure that shouldn't impede the electrical connection (I hope)
Old Oct 9, 2009 | 01:10 PM
PLC7.3's Avatar
PLC7.3
REMEMBER THE TORQUE ON GP'S is only 12 foot pounds or 1/12 of a turn..... after bottoming......if you did it above that redo them to spec or you will pay later.
Old Oct 9, 2009 | 10:57 PM
JHoffman93's Avatar
JHoffman93
What will happen if you over tighten glow plugs?
Old Oct 10, 2009 | 09:40 AM
Dave Sponaugle's Avatar
Dave Sponaugle
When you try to get them back out after the engine has been running a while, you will probably have a lot of fun.
I use a "light" coat of never sieze on mine when I install them.
kmjone00
Testing.....
Sep 19, 2016 10:30 PM
Snowseeker
Wisconsin Chapter
324
Aug 7, 2016 12:59 PM
Big-Foot
Minnesota Chapter
578
Jun 1, 2016 06:22 AM
chukar
Mar 20, 2016 02:10 AM
