360/390 engine
Old Oct 8, 2009 | 11:43 PM
410 Highboy's Avatar
410 Highboy
In 1967 ,I inherited a 1960 Fairlane 500 with a 352 4 barrel ,yellow valve cover ,and air cleaner.Was that an intercepter ?
Old Oct 9, 2009 | 04:04 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Yes, it was.
Old Oct 9, 2009 | 04:46 AM
bumsy's Avatar
bumsy
great piece.i just bored my 360..060, stoked,390 crank with custom cam. balanced. run, sounds good. 9.5 compression. 10+ mpg. in 74,f250 hi-boy . again good job. if had to do over would have rebuilt 460 and get it over with...
Old Oct 9, 2009 | 07:13 AM
Kalve's Avatar
Kalve
An why won't a 5 or 6 speed manual trans work with a 360 or 390?
Old Oct 9, 2009 | 11:06 AM
Bear 45/70's Avatar
Bear 45/70
No bellhousing to mate the engine and the trans together.
Old Oct 9, 2009 | 02:50 PM
85e150's Avatar
85e150
The NV4500 can be installed with an adaptor. The Ford issued 5 and 6 speeds have integral bellhousings in non-FE patterns.
BTW, have you priced aftermarket FI? Got $1000?
Check another dealer or go through the TSB's listed to see if there is a fix.
http://www.chevyhhr.net/forums/forumdisplay.php?f=42
Old Oct 11, 2009 | 01:20 AM
George Frasier's Avatar
George Frasier
Have a '75 F-250 SC with 435 4-spd and 4.10 rear. It had power to spare and scooted down the road quite fine, till it was "loaned out". Am rebuilding a 390 to replace the 360 - will add headers and swap the 4 barrel off the 360 onto the 390 (2 barrel ) The base difference is the 360 seems to be a "destroked" 390. Am looking forward to starting out in 3 gear again.
Old Oct 12, 2009 | 04:15 AM
Broncoholic1's Avatar
Broncoholic1
Originally Posted by George Frasier
Have a '75 F-250 SC with 435 4-spd and 4.10 rear. Am looking forward to starting out in 3 gear again.
For what is it icy down there? Or you like the smell of clutch in the morning?
Old Oct 12, 2009 | 07:01 AM
George Frasier
Broncoholic1 - I didn't make a habit of starting out in 3d gear. The engine at that time was running very strong/ good clutch. I did it just to show some Chebby friends that "I could". Their 350's would stall out. Also had a 4.10 rear to help out. They could take me for 0-60 - BUT - chaining the rear bumpers together, I cuold pull them - I had the tires & weight advantage.( still have the Ford canopy attached )
74f100sc
15
Feb 23, 2016 11:26 PM
Ford360dude
Jul 11, 2012 10:49 AM
pin04005
Apr 1, 2011 03:59 PM
vscrl
Feb 11, 2010 12:16 PM
bigtrucks1
19
Jul 25, 2009 07:54 PM
