oil change
Old Oct 7, 2009 | 08:51 AM
breisr's Avatar
breisr
oil change
I want to start changing my own oil. I have a 95' 300i6. They have been putting regular 5W-30. Can and should I start using a synthetic oil? Truck has 120,000 miles. If so, what brand and how many quarts. What type of oil filter as well?
Thanks,
Ryan
Old Oct 7, 2009 | 09:15 AM
1OldFordMan's Avatar
1OldFordMan
I would say no problem with switching. Should hold 5 quarts. Personally use Fram filters. Have seen several people on here saying don't. Have used Fram all my life. Your truck, your choice.
Old Oct 7, 2009 | 09:16 AM
breisr's Avatar
breisr
will i have a problems with leaks going from regular oil to synthetic?
Old Oct 7, 2009 | 09:30 AM
quicklook2's Avatar
quicklook2
6 quarts with filter.
fram filters sucks.
use motorcraft filter.
use regular oil.
Old Oct 7, 2009 | 09:41 AM
breisr's Avatar
breisr
what type of synthetic?
Old Oct 7, 2009 | 09:49 AM
breisr's Avatar
breisr
Quicklook2:
why not synthetic?
Old Oct 7, 2009 | 09:58 AM
quicklook2's Avatar
quicklook2
do it if it floats your boat.
i do not see any reason for the expense of it.
Old Oct 7, 2009 | 10:07 AM
breisr's Avatar
breisr
i agree, if there is no advantage to synthetic why waste the money. but if there is ANY advantage I am willing to pay the extra $$.
Old Oct 7, 2009 | 10:30 AM
Ricache's Avatar
Ricache
I believe that you should use synthetics as soon as possible on a new engine. That's where you should see significant value for the "investment". I put M1 in my '01 Durango with 4.7 V8 at 500 miles and it still purrs like a kitten at 98K miles. I bet the innards are nice and clean.
In a high mileage or older engine I don't see the benefit. Good quality name brand oil will do just as well.
On the Fram - I've heard on a few forums about it's flaws.
I've been using Fram but on my next oil changes (both vehicles) I'll go with Motorcraft or Wix (sp?) or other high quality oil filter.
/Ricache
Old Oct 7, 2009 | 10:40 AM
breisr's Avatar
breisr
thanks guys for the info.
Old Oct 7, 2009 | 11:55 AM
TexasGuy001's Avatar
TexasGuy001
I would not switch to synthetic. Especially with 120k on the clock. Just keep your oil changed so its clean and that should be fine.
I have 275k on my truck with the original drivetrain. I have always just used conventional oil.
Don't use Fram. Use Motorcraft, Wix, or Purolator.
Old Oct 7, 2009 | 01:04 PM
breisr's Avatar
breisr
I gonna start running Rotella-T (non-synthetic) 11.99/GAL and a napa gold filter.
thanks,
Ryan
Old Oct 7, 2009 | 02:18 PM
quicklook2's Avatar
quicklook2
why the heavy weight diesel oil?
Old Oct 7, 2009 | 02:40 PM
breisr's Avatar
breisr
It's 10-30 and my grandpa has been running it in his 87 300 with good results.
Old Oct 7, 2009 | 04:21 PM
quicklook2's Avatar
quicklook2
5w30 is what grandpa ford says to use.
