oil change
Old Oct 7, 2009 | 04:57 PM
breisr's Avatar
breisr
Originally Posted by quicklook2
5w30 is what grandpa ford says to use.
lol! now that's funny.
Old Oct 7, 2009 | 06:54 PM
wolfsmurf's Avatar
wolfsmurf
the main reason not to switch to syn oil on an older engine is the leaks it may produce. syn oil is thinner and runs easier so in an older engine that may drip a bit here and there with regular oil with syn oil it could really pore out. other than that there is no problems.
i agree about the fram filters as well. buy a motorcraft and forget it.
Old Oct 7, 2009 | 07:01 PM
bazzman1953's Avatar
bazzman1953
To use Rotella in a gas engine sounds like a bad choice. Just get a bad feeling about it. As for Fram, thanks, but no thanks on that chinese junk. It's only a matter of time before Harbor Freight starts selling them. A good quality 5w30, which is already a semi-syn oil [the 5w part] will work just fine. Too many miles to bother with now.
Old Oct 7, 2009 | 07:29 PM
quicklook2's Avatar
quicklook2
5w does not mean synthetic.
we had 5w30 oil way before synthetics or semi synthetic came out.
Old Oct 7, 2009 | 07:35 PM
Chevy 6.2D's Avatar
Chevy 6.2D
The only thing I'm going to say is I've noticed my oil stays cleaner a LOT longer when I use a WIX filter. With a fram it would be black at 1000 miles but when I use a wix it still looks good even at 3000.
Old Oct 7, 2009 | 07:38 PM
94XLT5.0's Avatar
94XLT5.0
Who makes K&N oil filters?
Old Oct 7, 2009 | 07:49 PM
wolfsmurf's Avatar
wolfsmurf
i havent seen any other filter on the market made even remotely like the k&n filter in 15years selling parts. im sure someone with enough time could find that tidbit on the net somewhere.
Old Oct 7, 2009 | 07:52 PM
ademonte5's Avatar
ademonte5
oil
hi i just put a fram filter on today but i have a motor craft one can i just change firlters instead of doing a whole oil chage over??
Old Oct 7, 2009 | 07:57 PM
94XLT5.0's Avatar
94XLT5.0
I thought maybe WIX made them. I have always had good luck with them, but I guess i've never had bad luck with any oil filter so....
Old Oct 7, 2009 | 08:00 PM
wolfsmurf's Avatar
wolfsmurf
jep. jus pull the other one off and install the new one, remember to adjust the oil lvl when you start it up. maybe 3/4 to 1 quart added prolly.
Old Oct 7, 2009 | 08:16 PM
mtmatzf150xlt's Avatar
mtmatzf150xlt
oil change
hey dude, as Ford certified tech, i wouldnt recommend swiching to synthetic, as odds are that its had conventional oil its whole life and you dont wanna risk potentially creating a leak. i would use conventional oil and preferable a motorcraft filter..about 6 quarts for the strait 6's. good luck
Old Oct 7, 2009 | 08:17 PM
bazzman1953
Regular oil can be refined down to 10w. Anything lower requires additional refineing [aka cracking]. Synthetics have been around since WW2.
Old Oct 7, 2009 | 09:04 PM
  #28
quicklook2's Avatar
quicklook2
not in an arguing mood tonight.
some believe in religion and some don't.
same thing here.
Old Oct 7, 2009 | 09:05 PM
  #29
EPNCSU2006's Avatar
EPNCSU2006
Champion Labs makes the K&N oil filters, along with several other brands. The filter media in the K&N oil filter and Mobil1 oil filter is identical.
While many synthetics use a cracked base oil, the cracking process itself does not make the resulting product synthetic by default. There are plenty of non-synthetic 5w30 oils.
Old Oct 7, 2009 | 10:35 PM
  #30
IowanStraight6's Avatar
IowanStraight6
Dont steer away from rotella t it lubricates way better and has alot more zinc in it than other oils it is also gas rated too some use in there motorcycles when crane cams was in buisness thats the only oil they would warenty there cams with i think thats for a reason also I use 15w-40 late spring, summer and switch to 10w-30 late fall, winter I just dont trust that thin 5w-30 and i use a fleetguard lf697 (motorcraft FL299) just higher gpm filter its a larger version of FL1A Truck loves it
