1994 ford ranger supercab
Old Oct 6, 2009 | 09:35 PM
daddysgirl1940's Avatar
daddysgirl1940
1994 ford ranger XLT 4.0 2 wheel drive 5 speed manual trans, after sitting in uphill incline driveway for 2 weeks my truck does not want to shift gears,,after sitting at idle for a few minutes you can slide it from gear to gear but if you drive down the road and come to a stop it does not want to shift into any gear easily. could it possibly air in the lines,was told to check the fluids.
- ok drained the transmission oil in the Manuel transmission, could not get fill plug of so took the shifter off to fill it and when we did the the shifter bushings were in pieces. so we took a shot in the dark and replace them , there is still no change in the shifting i drove it down the road thinking maybe oil needed to circulate, but still no change have to fight it to shift it. if you are just sitting still it will shift from gear to gear but if you let it roll backward about 3 inches you play hell getting into first gear, but if i kick the clutch really hard to the floor it slides in with ease, i thinking maybe the master cylinder is bad? as i said before had absolutely no signs of any problems i just got from a 1600 mile round trip went to my sons for a few weeks and when got ready to go home it just all the sudden didn't want to shift, i know normally if the clutch is going out there are some signs, on most trans problems.... Please help winter is coming and I do in home care for Hospice and need my truck. thanks
Old Oct 7, 2009 | 01:48 AM
Fomoko1's Avatar
Fomoko1
Welcome aboard daddysgirl1940, help is here in the FTE forums. Re post your question in the Ranger & B-Series forum: Ranger & B-Series - Ford Truck Enthusiasts Forums
Also check out the fine folks in your local ID chapter as well: Idaho Chapter - Ford Truck Enthusiasts Forums
Old Oct 7, 2009 | 03:39 PM
1Aauto's Avatar
1Aauto
Former Vendor
Welcome to FTE
thepigstye
New Member Introductions
Jun 8, 2008 08:13 AM
RDA
Feb 1, 2008 11:31 PM
NWinsomniac
Jan 28, 2008 09:39 PM
midge555
Nov 29, 2006 05:31 PM
J.Hud
Feb 12, 2005 05:33 PM
