TorqShift Transmission Flush Question
So I have another 55,000 miles before my transmission is due for a service, but I was thinking about how I could go about doing that without paying for labor.
I remember reading awhile ago that the 5R110 requires a type of flush machine that will heat the clean fluid to 170 degrees or else the thermostat will stay closed and no fluid will circulate to the cooler, thus making the flush difficult.
But what about finding a way to heat the fluid at home? If I could theoretically heat the fluid to around 190 or so and pour it in as hot fluid was being pumped out, wouldn't everything come out okay? Or is there something I'm not thinking of here...
Here's how to do it for a 4R100: Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles
If you heat the trans and the new fluid, and use MERCON SP, you could use these instructions. The procedure is the same.
Interesting. The trans should be serviced every 30,000 miles.
You will need to warm the trans up to at least 175°F to start to be sure that the thermostat is open. Heating the fluid going in is the way to do it.
So the thermostat opens at 175, huh? I think this can be done. Has anyone done this before?
Yes, not to mention the burn dangers of handling said hot fluid through kitchen, into garage, spills on honey's new tile in the laundry room ect ect ect.
Maybe just change half now, half later by simply draining and filling back up. You are replacing 50%, then second time 75%, if you are that resolved not to pay to use the heated flush.
Hah, you guys are funny!
Never thought too much about the logistics of heating and pouring 5 gallons of hot fluid, though. A thought that comes to mind are maybe an electric heating element in a 5-gallon bucket. I'd have to make sure my hand pump was rated for those temperatures...
Definitely wouldn't do it in the kitchen. You guys probably wouldn't see me around much after that...
Sam
I've seen people talking about paying upwards of $200 for the service at the dealer.
Is it worth it to you?
